JDP Motorsports
Old 05-31-2013, 01:34 PM   #1
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
Service Tire Presure monitor system
I finally took my car out of storage, and the tpm system read nothing. I figure no big deal, as the battery was disconnected. i release the extra air and drove around and hit relearn and still nothing. I even put in more air and released it just to let it flow through the monitors, and still says service system. Anything else i should try, or it is a trip to the stealership,
ZL1 10 spokes, Vigilante 3400 TC, Pfadt Springs, Pfadt front and rear sway bars, Roto Fab Cai, SW Long Tubes no cats,Bo White Throttle Body, Dr Phil Tune,GHL Cat back, AAC Side markers, 20% Tint all around
gm2376 is offline   Reply With Quote
Old 05-31-2013, 05:00 PM   #2
Chevrolet Customer Svc
Drives: GM Vehicles
Hello gm2376,
Sorry you're having some issue's currently. Could you private message me your VIN and current mileage. I will see if there is any information I have on this issue for you.
Reggie B.
Chevrolet Customer Care
Chevrolet Customer Svc is online now   Reply With Quote
Old 05-31-2013, 07:45 PM   #3
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
If your quote above is the way you did it, you did it all wrong. Look in your owners manual. It's simple on the 10's, others...not so much.
The procedure is listed on page 9-60 in the owners manual.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 05-31-2013, 07:54 PM   #4
gm2376
gm2376's Avatar
i did it the way you do all gm cars with tpms....start the relearn, let out air in the front passenger until the horn beeps....problem no beep.....can't deflate my entire tire to see what happens.
Old 05-31-2013, 08:01 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
You don't need to let a lot of air out, just barely press the needle thingy down and only a little air gets out.
Click to view my build thread
Old 05-31-2013, 08:18 PM   #6
SSMickey
SECC
SSMickey's Avatar
That's not what you said in your OP... but anyway. Put the TPMS in relearn and start with the DRIVERS FRONT, let air out until the horn beeps once, then do the same with the passenger front, passenger rear, drivers rear in that order. After the relearn is done, you'll get a double beep. Turn the key off and air your tires back up to the correct pressure. If you start with any tire other than the LF, the relearn should work, but the system will report the wrong pressure per tire. If you have no way of adding air to your tires after the relearn, any tire shop should be able to do this in about 5 minutes.
Old 05-31-2013, 08:52 PM   #7
gm2376
gm2376's Avatar
Already tried that. Didn't work.
Old 05-31-2013, 11:05 PM   #8
SSMickey
SECC
SSMickey's Avatar
Then I would take it to a tire shop and let them use there tool on it. I can do a re-learn myself with my stock wheels, but I have to have the tool to trigger the sensors with my Forgelines. I know, weird.
Old 05-31-2013, 11:23 PM   #9
Avenging Orange
Avenging Orange's Avatar
Or, you can rely on your brain and a tire gauge.
Sorry, couldn't resist.
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413
2015 Ford Interceptor// 2007 Ford F150 XLT 4X4
Avenging Orange: 40 years of not buying into the Hype........and damn proud of it!!
Old 06-01-2013, 12:46 AM   #10
gm2376
gm2376's Avatar
Or since its in warranty and only has 3000 miles, it can be fixed so I dont have a warning and and a tpm symbol lit on my dash
Old 06-03-2013, 12:44 AM   #11
Avenging Orange
That was easy, huh? Could have done that to begin with.
Old 06-03-2013, 08:24 AM   #12
gm2376
gm2376's Avatar
And what would be easy? Taking it to the dealer? Considering I have a job , a family and limited time, making a appointment and dropping off a car and having someone take me home or wait is not easy. Thanks for the worthless posts and comments. Always need a few of those in a thread.
Old 06-03-2013, 08:32 AM   #13
Bpw72
Bpw72's Avatar
Drives: 2011 camaro ss convertible 2ss/rs
Not sure if the 2010 is different than the 11's but I find relearning on mine works quicker when I put air in the tires instead of taking it out.
Bpw72 is offline   Reply With Quote
Old 06-03-2013, 09:36 AM   #14
gm2376
gm2376's Avatar
Thanks....i'm at the dealer right now. he said they lost frequency, they are using a tpms tool? never seen it before, they put it near the tpms and i guess it re syncs the frequency.
