Old 05-31-2013, 03:14 PM   #1
htoniv
Drives: Camaro
CEL with code P2176
Hey guys, i could use a little bit of help here.
I got a check engine light a couple days ago, so i looked up common causes and tried doing some fixes, i tightened my gas cap properly, filled up with fuel injector cleaner and 93 oct at BP and still it stayed on. So i went to autozone today and they gave me the error code
Error Code: p2176
Sensor 1 and APP sensor 2 signal voltage fault
Explanation:
The ECM has detected the APP sensor signal 1 and 2 do not agree
Probable cause
1. Poor electrical connection
2. Failed APP sensor
So i did bit of search there is not too much on this code that i could find, but what i did find seemed to point to throttle body issues, sludge build up on it and etc. Forum member recommended just cleaning it properly.
I will be trying that this weekend but i would appreciate any additional advise and help to this matter
Thank You
Edit: i forgot to mention i have installed a ported TB since Early last month.
-Vin
htoniv is offline   Reply With Quote
Old 06-01-2013, 02:24 PM   #2
htoniv
Drives: Camaro
Bump guys, anyone?
Old 02-09-2014, 01:49 PM   #3
BudMC77
BudMC77's Avatar
Drives: 2011 Camaro 1LT
Bump bump.
Got the same code coming up on mine as well.
BudMC77 is offline   Reply With Quote
Old 02-09-2014, 02:05 PM   #4
BlackoutLFX
BlackoutLFX's Avatar
Drives: 2012, Black 2LS
The P2176 code is set when the difference between the predicted and the actual throttle position is more than a calibrated amount for more than 1.5 seconds.
Possible Causes.
Faulty Throttle Actuator Control (TAC) module
- Throttle Actuator Control (TAC) module harness is open or shorted
- Throttle Actuator Control (TAC) module circuit poor electrical connection
- Throttle plate sticking due to carbon build-up
- Engine Control Module
The Engine Control Module (ECM) is the control center for the Throttle Actuator Control (TAC) system. The ECM determines the drivers intent and then calculates the appropriate throttle response. The ECM achieves throttle positioning by providing a pulse width modulated voltage to the TAC motor. The TAC system uses the following circuits for Motor control 1 and Motor control 2.
Two processors are also used to monitor the TAC system data. Both processors are located within the ECM. Both processors monitor each other's data to verify that the indicated throttle position is correct.
Read more: http://engine-codes.com/p2176_chevro...#ixzz2sqy9NvB9
Nytrex 100 hp nitrous triple threat system, NytrexAccu-pressure bottle heater, HP tuners, K&N Typhoon CAI, MACE 6mm MI, Solo Performance high flow cats, Flowmaster American Thunder cat back exhaust system, BMR subframe connectors, BMR tunnel brace, BMR lowering springs, BMR Xtreme Anti-roll bar rear, Hotchkins Strut brace, SS/LS3 3.45 LSD, Axles, and hubs, Elite Engineering catch can, B&M Supercooler transmission cooler, FTI 3200 Stall.
BlackoutLFX is offline   Reply With Quote
Old 02-09-2014, 09:24 PM   #5
c_cook94
c_cook94's Avatar
Drives: 2011 Rally Yellow 1LT
I had this problem last summer with mine. I ended up getting a whole new TB
c_cook94 is offline   Reply With Quote
