Old 06-01-2013, 09:48 AM   #1
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
what shifter for 4l80e swap?
i was planning on just using the stock. but what are you guys using?
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 06-05-2013, 10:46 PM   #2
Rdunn
Really, Really Fast
Rdunn's Avatar
bump
Old 06-05-2013, 10:50 PM   #3
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Stock for auto-shift transmissions and the B&M Stealth Pro Ratchet for the manual shift trans...
Matt @ FSP is offline   Reply With Quote
Old 06-06-2013, 01:56 AM   #4
Rdunn
Really, Really Fast
Rdunn's Avatar
thanks. looks like im sticking with stock then.
Old 06-06-2013, 09:44 PM   #5
429
Drives: 2010 camaro ss
stock is easiest.
429 is offline   Reply With Quote
Old 06-06-2013, 09:48 PM   #6
Rdunn
Really, Really Fast
Rdunn's Avatar
sounds good. im using the pcs controller
Old 06-18-2013, 02:09 AM   #7
BLACK10
BLACK10's Avatar
Stock works perfect
Old 06-18-2013, 08:37 AM   #8
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Ill have a modified stock one in a couple weeks available with console lid.
From our 4l80 Whipple nitrous car.
http://www.camaro5.com/forums/showthread.php?t=170236
ADM PERFORMANCE is offline   Reply With Quote
Old 06-18-2013, 10:07 PM   #9
blake-b
blake-b's Avatar
Drives: Black 2010
Andy, the pics aren't there anymore. There is a tinypic box that says the video or image has been moved or deleted. First post on page two of the thread.
Old 06-18-2013, 10:21 PM   #10
jrpxxii
jrpxxii's Avatar
I used the stock one when I had the 4l80 as it was cool to look inside the car and think its still just stock. Ive now swapped to a th400 and running the Cheetah speed shifter.
Old 06-18-2013, 10:24 PM   #11
Supercharged SS
Drives: 2010 Camaro
You still have your car?
Old 06-18-2013, 11:04 PM   #12
Allanski
Drives: Car
Probably this if you want to race
Allanski is offline   Reply With Quote
Old 06-22-2013, 09:57 PM   #13
CamaroSS45
Annihilator
CamaroSS45's Avatar
Drives: 2012 45th ERL-427 F1X
Lightbulb Guys - 4L80e swap.... (Opinions and Inspiration ;) ...
Guys - headed here in a few weeks... Probing the boards and all of the posts from the many smart folks here that went 4L80e - and experiences. If you have any words of wisdom - tips - guidance - or links a PM would be BIG TIME appreciated... I know there is a a killer FAQ....
Like any moron, we worked on the rebuild for about 8 months plus, got our Dyno pulls done, managed some solid shakedowns, and now working to get away from the M6 to a 4L80e. Was actually planned all along but wanted to get to this point first.
Thanks again and know many of you have lived thru this. Going to 4L80e to keep some street drive in the car at least for now.
Converter should be in next week, 4L80e pretty heavily built for our HP the following week - curious on cooling and all of the other key elements of moving from M6 to this config ... and shifter just happens to be a small one but certainly important....
Thx all....
ERL M3 Superdeck 427 Forged, Dragon Slayer Crank, Black Label Heads : ProCharger F1X Cog - Holley HighRam : Jakes4L80e CircleD - DSS 9" 1400 axles/shaft, BMR Suspension : Extreme Innovations 15 : Squash, Bosch 127lb FI : ALKY Twin Meth
CamaroSS45 is offline   Reply With Quote
Old 06-22-2013, 10:29 PM   #14
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i,m sure you probably did homework , but here is a good red , if you have not read it yet..also i used stock..http://www.camaro5.com/forums/showth...light=diy+4l80
mikepage0007 is offline   Reply With Quote
