JDP Motorsports
Old 06-01-2013, 12:34 PM   #1
KodyJoe
KodyJoe's Avatar
Drives: 2010 White Camaro SS
Trouble pulling 6L80e!!
Soo 9 hours of me and my buddies trying to get the damn thing out and I'm lost. Got all 7 bolts out of the bell housing, got the stock torque converter unbolted, all the lines are off, all the wires and disconnected. Is there something ontop of the transmission that needs to be unbolted? The tranny at the bottom is pulled away far enough you can stick your hand up to the flex plate but at the top the gaps closer maybe an 1/4". Anyone pulled a 6l80e?
L99 with CAI, LT Headers, Full Exhaust, and Dyno Tune 374.73 rwhp and 397.18 ft-lbs.
KodyJoe is offline   Reply With Quote
Old 06-01-2013, 01:34 PM   #2
429
Drives: 2010 camaro ss
pull harder.
429 is offline   Reply With Quote
Old 06-01-2013, 05:05 PM   #3
SC2150
It takes 1 tech an hour or less to drop out....your doing something wrong.
Shifter, bellhousing bolts, torque converter from flex plate, driveshaft, cooling lines, and cross member.
Old 06-01-2013, 07:53 PM   #4
Motion427
Drives: 2010 2SS/RS Red Jewel L99
I took my tranny out yesterday.
I think I counted 8 bolts and not 7.
Motion427 is offline   Reply With Quote
Old 06-01-2013, 08:06 PM   #5
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
you're missing the very top bolt. Should be 8 bolts total. Lower the back of the trans down some and you will see it.
there's 9 bolt hole total in the bell housing but the top left bolt is not used.
Zoom in on the picture.
Sent from my HTC One using Tapatalk 2
Nitroman28 is offline   Reply With Quote
Old 06-01-2013, 11:03 PM   #6
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Yup there's a bolt at the very top of the bell housing.
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 06-02-2013, 12:58 PM   #7
Netraa
Drives: 2014 2ss/rs
And just to state the obvious, If you have a 1/4 inch gap at the top of the transmission already, I would be very, very sure you have as little strain on the bolt as possible when you do try and remove it. And... replace it when it's time to bolt stuff back together.
Netraa is offline   Reply With Quote
Old 06-05-2013, 03:39 PM   #8
BLACK10
BLACK10's Avatar
30-40mins
Old 06-05-2013, 04:38 PM   #9
SC2150
Originally Posted by BLACK10 View Post
30-40mins
Well, were not ALL supermen!!
6l80e, diy, issues, stall, torque converter
