SDTW Custom Wheels & Tires
Old 06-01-2013, 05:41 PM   #1
R8E1D
R8E1D's Avatar
Drives: 2013 Ram 1500
Valve seat broke and valve seal gone!
Size:  160.8 KBI pulled the valve cover today to check everything out. The left bank had a piece of rubber and a very thin metal shaving in it. I Found the first pic. Pulled those springs and the intake seat was in 3pieces and the exhaust seal was gone. Any one know what would cause this? I installed the JRE rough idle cam kit about 8k miles ago. I had no symptoms that any thing was wrong. Thanks for the help.
Red
R8E1D is offline   Reply With Quote
Old 06-01-2013, 05:44 PM   #2
R8E1D
R8E1D's Avatar
This was how it looked before I pulled the springs.
Old 06-01-2013, 06:28 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
What springs are those? What's your pushrod length?
Old 06-01-2013, 06:37 PM   #4
R8E1D
R8E1D's Avatar
Comp 926-16 dual springs and comp 7955 pushrods 7.4 length.
Old 06-01-2013, 09:42 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
926 springs are no joke regarding spring pressures. I have those same ones but because I'm using an LsR cam. I doubt that cam has aggressive lobes like that, with that being said do you warm up the car to operating temps before getting on it? Do you make that a habit or do you just turn on and Go?
Old 06-01-2013, 09:46 PM   #6
R8E1D
R8E1D's Avatar
I ALWAYS warm it up first. I have read the threads about broken springs.
Old 06-01-2013, 10:08 PM   #7
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Those small bits went somewhere. That would have me worried. Good luck.
Old 06-01-2013, 10:13 PM   #8
R8E1D
R8E1D's Avatar
Most of the big chunks were still inside the spring. I just changed the oil about 100 miles ago. I am going to open up the filter and see what it caught. Hope for the best I guess.
Old 06-01-2013, 10:40 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Gotcha! Good practice to warm it up.
Did you check the installed height?
Old 06-01-2013, 11:05 PM   #10
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
That's the spring seat not the valve seat. I at first thought you had a valve seat failure which would have been a lot worse than this.
Old 06-01-2013, 11:47 PM   #11
BLACK10
BLACK10's Avatar
the spring seat make have not been fully seated in the right place. it may have been hung up on the head
Old 06-02-2013, 08:49 AM   #12
R8E1D
R8E1D's Avatar
Litle, they were all at 1.8 on the install.
Old 06-02-2013, 09:36 AM   #13
NC-V
NC-V's Avatar
Drives: cts-v
This was my thought as well. If it maybe sat a little crooked or a small piece of debri fell under the seat as it was being installed leaving an air gap under the seat.
NC-V is offline   Reply With Quote
Old 06-02-2013, 10:54 AM   #14
R8E1D
R8E1D's Avatar
I believe that's why the spring seat broke, but I wonder why the exhaust valve spring ate the valve seal. Maybe the ID of the spring is tight? The car didn't smoke at all. Just weird to me.
