SDTW Custom Wheels & Tires
Old 06-01-2013, 07:13 PM   #1
Arodr395
Arodr395's Avatar
Drives: 2014 Black Camaro 2SS/RS 1LE
1LE Rear Tire Size
Are the rear tires on the 1LE wide enough? Because I know in certain photos the rear tires look too skinny.
Arodr395 is offline   Reply With Quote
Old 06-01-2013, 07:19 PM   #2
1Slow6.2
1Slow6.2's Avatar
Drives: 2013 1LE camaro
285's are pretty damn wide IMO.. I get compliments everywhere I go.
Sent from my hip pocket.. While slapping 5th.. As your reading my plate
1Slow6.2 is offline   Reply With Quote
Old 06-01-2013, 07:20 PM   #3
Jc's1LE
Drives: 2015 SW 1LE BA NPP Recaros
they are stretched for a reason to keep more foot print on the road when you are out tearing up turns
Jc's1LE is offline   Reply With Quote
Old 06-01-2013, 07:25 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
you're*
Click to view my build thread
Old 06-01-2013, 07:40 PM   #5
Arodr395
Arodr395's Avatar
I agree that 285's are pretty wide, but then again you have to remember that the Camaro is a pretty big car for a sports car. I like my cars to have a wide stance in the rear, and in my opinion I feel that the 1LE would look better if it had the 305 rear tires that the ZL1 has.
Old 06-01-2013, 07:42 PM   #6
Cody6.2
Drives: 2012 Camaro 2SS
Ummmm, no...
Cody6.2 is offline   Reply With Quote
Old 06-01-2013, 08:11 PM   #7
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Thats exactly why they are stretched.They found that this is the set up that makes the 1LE one of the best handling cars on the road, period.
cornerspeed92 is offline   Reply With Quote
Old 06-01-2013, 08:11 PM   #8
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Originally Posted by Cody6.2 View Post
Ummmm, no...
Actually yes, a stretched tire on a rim will handle better than the same sized tire on a narrower rim. Ie find the widest rim that will fit and get the narrowest tire on that rim.
Now looks are a different story...
BigBlock69RS is offline   Reply With Quote
Old 06-01-2013, 08:20 PM   #9
Cody6.2
Yet the tire/wheel combo that does the most work aren't like this......
Old 06-01-2013, 08:32 PM   #10
racerx1214
Drives: 2013 1LE
There was an quote from one of the engineers that stated that was the reason.
I believe them.
They understand things better than a hillbilly with a mullet car thinking wider is always better.
racerx1214 is offline   Reply With Quote
Old 06-01-2013, 08:35 PM   #11
Cody6.2
I believe them.
The same engineers also said the larger lower grille on the 2014 let more air in. Yet if you actually look at it the actual opening is the same if not smaller than the 2010-2013.
I guarantee if you put a ZL1 rear tire on a 1LE that handling would be better not worse.
Old 06-01-2013, 08:58 PM   #12
racerx1214
Drives: 2013 1LE
I guarantee you're wrong.
Old 06-01-2013, 09:01 PM   #13
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
The reason they are 285 is for neutral handling, cars with wider rear tires tend to be less consistent/predictable on the track. Running a square set of tires gives a better more in tune feel to the car and is much more predictable, 285 seems to be that nice medium.
Ive been running time trials, lapping days and autox's for about 10 years now and noticed that driving a car square set of tires gives you a bit more confidence as well.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 06-01-2013, 09:01 PM   #14
Ajdin@A2BMotorsport
probably loose a second per lap with a 305 rear.
