Old 06-01-2013, 09:10 PM   #15
racerx1214
Drives: 2013 1LE
Maybe Cody knows more than this guy:
You know, the engineer of the car.
Check the 40 second mark if you need to get right to it.
Cody,
http://careers.gm.com/#.html
You might as well apply here, to take this guy's place.
racerx1214 is offline   Reply With Quote
Old 06-01-2013, 09:17 PM   #16
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Cody,
I don't think so,but my question is, when you're so wrong(Cody)why do you keep coming back for more? when im wrong i just shut the hell up.
cornerspeed92 is offline   Reply With Quote
Old 06-01-2013, 09:18 PM   #17
Cody6.2
Drives: 2012 Camaro 2SS
Cody,
Do you ever look at your car underneath or from any kind of technical aspect? If you did it would be pretty clear that things weren't made from a what's best perspective. This car was built to match a picture someone with little car knowledge drew up.
Cody6.2 is offline   Reply With Quote
Old 06-01-2013, 09:19 PM   #18
racerx1214
Drives: 2013 1LE
Bro.
Nobody's wrong on the internet.
Old 06-01-2013, 09:20 PM   #19
Cody6.2
That's just it as a square set of wheels/tires (same dimensions front & rear) is just that not stretched tires on the back.
Old 06-01-2013, 09:20 PM   #20
Cody6.2
Bro.
Common sense would kill this place.
Old 06-01-2013, 09:22 PM   #21
racerx1214
Drives: 2013 1LE
What does this have to do with you being completely wrong about the topic we are currently speaking of.
I had a GTO and a Coyote Mustang before this.
You are most likely a better engineer than the designers of those two cars as well because this platform looks lightyears more solid underneath or from a "technical" aspect than either of the above.
Old 06-01-2013, 09:24 PM   #22
racerx1214
Drives: 2013 1LE
Have you been drinking?
Old 06-01-2013, 09:24 PM   #23
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
I don't road race so I installed the 305's for looks and grip in a straight line. Someone already said it, wider body needs a fatter tire as far as appearance goes.
white1LE is offline   Reply With Quote
Old 06-01-2013, 09:29 PM   #24
Arodr395
Arodr395's Avatar
Drives: 2014 Black Camaro 2SS/RS 1LE
Cody,
Does having the same tire size in the front and the rear make a car handle better and gives better times around the track? Or does having the tire stretched in the rear just create a better performing car around the track?
Arodr395 is offline   Reply With Quote
Old 06-01-2013, 09:29 PM   #25
Cody6.2
My last few cars were 2006 GTO, 2007 C6, 2012 Camaro and now a 2014 Mustang GT. So I must say that I got a pretty good chuckle out of that statement. Just like I laugh every time one of you mention engineers like they gave a **** about half the stuff you're talking about.
Old 06-01-2013, 09:30 PM   #26
natmad
natmad's Avatar
Drives: WTB '16 1SS Magride NPP Recaros 6m
There's some truth in all the posts above, I believe.
After much reading , I'm convinced that after much testing , the engineers (I'm using this term in a positive light) found that the 1LE handled the best with the current tire and wheel setup.
While the wider 305 rear tires would ultimately give the rear end more grip, they found that the stretched 285 rear tires, near the limit, allowed the 1LE to rotate slightly better in the turns with more nuetral handling, making it faster and more fun. If you can get a car to rotate in the turn, you can get back on the gas sooner than if the car is pushing. Of course, too much rotation--loose as hell--is slower too. If anything, the 1LE is balanced.
On the ZL1, the wider rear tire tires are necessary because of the extra weight and especially the extra power. Powah!!
natmad is offline   Reply With Quote
Old 06-01-2013, 09:31 PM   #27
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Yes. From the video here's what Al says.
front tires is stretched onto 11" rear wheel on back
why? b/c this is a track car
for track you don't' want to push that tire track down by having down force or have too much grip in the back, it's contrary to trying to fix the under steer.
we have the front splitter and rear spoiler which is to help with the grip.
we wanted to loosen up the slip and allow you to actually ring this thing out b/c in track mode this is a track car.
Sent from my iPad using Tapatalk HD
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 06-01-2013, 09:32 PM   #28
CrystalRedTintcoat
You need to research the wheel size. You're wrong.
2013 1LE NPP GBE
Mods
Track Days
