Old 06-01-2013, 08:56 PM   #1
Rhaas2001
Rhaas2001's Avatar
Drives: 97 Camaro Z28 Lt1 6 speed
Crazy idea
First off this may be in the wrong place on the form, if so let me know or just move it. correct me if I am wrong at any time but, has any one noticed every one has a fith gen. That's a great thing, but does anyone know if any one has a 1970-72 true z28 with a ls7 6 speed drive train? Has any one on this form ever tried to ingrate the fith gen systems into a older generation, like traction control for example. I ask because if the new z may be priced at $65k plus it gives someone (maybe me) a high enough budget to try given what I have all ready priced in parts this far. altho builds always run over budget i realize. Any and all thoughts are welcomed, even if there not constructive lol
Rhaas2001 is offline   Reply With Quote
Old 06-01-2013, 10:02 PM   #2
mkorgan
Drives: 1970-1/2 Z-28, 2017 ZL1
I have a buddy of mine who has a LS7, TREMEC 6 speed, and Detroit Locker rear in a 73' with all after market suspension and custom interior, etc..etc. It is a wonderful car which I have driven several times. If I remember correctly, he has well over $65K in the car but that includes a lot of extra's that you would not necessary want/need on a track only car. It does not have ceramic brakes/rotors which I believe are in the $10K range so you would have to add that on to get close to the overall Z/28 package to start. I think that recreating the Z/28's performance from a first or second gen Camaro would be pretty tough. The Red Devil has over $200K invested in it and while it is faster the than the ZL1 around the track it may not beat the new Z/28 based on the numbers we are seeing.
I think if you are talking about what it would cost to create an equivalent early gen Camaro to what is promised in the new Z/28...I don't think you could touch building one yourself for the cost of the new Z coming. But...I could be wrong.
mkorgan is offline   Reply With Quote
Old 06-01-2013, 10:39 PM   #3
LOWDOWN
Downright Upright
Drives: Daily
Go to DSE's website and you'll quickly spend $20K for a front-end/rear-end/wheels/tires for a Gen-1 or -2 F-body. Add $20K for a crate LS7/Tremec/misc. Now build a really nice body/interior...and pay for all the things not listed...
Makes the $60s...with a warranty...seem like not so bad a deal...
There are Pro Tour cars out there that easily have cost $100K+.
LOWDOWN is offline   Reply With Quote
Old 06-01-2013, 10:54 PM   #4
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
There's a company that sells bolt in IRS rear ends for first gen Camaros. I can't remember the name right now.
Bhobbs is offline   Reply With Quote
Old 06-01-2013, 11:09 PM   #5
LOWDOWN
Downright Upright
Drives: Daily
Heidt's
Old 06-01-2013, 11:31 PM   #6
Bhobbs
Bhobbs's Avatar
Originally Posted by LOWDOWN View Post
Heidt's
Yep, that's it.
I've thought about putting a C6 rear end under my 98.
Old 06-02-2013, 12:57 PM   #7
LOWDOWN
Downright Upright
Drives: Daily
Better to use a Gen-5 SS/ZL1 or CTS-V diff...mock it up...and re-sell it...
C-5/6 Corvette diffs include the rear-mount tranny/torque-tube...which would be a major refit in an F-Body...
Old 06-02-2013, 05:06 PM   #8
Rhaas2001
Rhaas2001's Avatar
thanks mkorgan and you guys for the info, it is nice to know that someone has done it. i can't or won't put 200k in a car build lol. but i do love the look and always wanted a early second gen. you also have a good point lowdown given the warranty it may come with. i on the list to order the new Z, i guess once options list and order form hit the dealer ill make my choice. thanks for all the info, you guys are great
Old 06-04-2013, 11:47 PM   #9
Bhobbs
Bhobbs's Avatar
I read about someone using a C5 rear end. There was/is a company that made an adaptor plate so you could use a standard T56 and driveshaft.
How much is an SS rear end going for?
Old 06-05-2013, 12:29 AM   #10
Col. Brain
Drives: 2012 Ram 1980 Malibu
You are better off heading over to pro-touring.com or lateral-g.net.
DSE is the top end of the equation. Roadster Shop makes a full frame alternative as well that is pretty neat but 15k or so for the whole thing.
Speed Tech has their "track attack" packages that have run pretty good numbers and that kit is about 12k just add gear, trans, and engine.
If you are playing with an older car you also do not need to use an LS engine. They are nice but 13k builds you a pretty beastly big or small block with efi or carb. LS7 505hp or a 650hp 427 sbc.
Will the car be faster than a Z/28? Maybe but probably not (unless you went full race car with it). However, you stand a better chance of your car retaining its value especially if GM sells a few thousand Z/28s.
Personally I think the Z/28 will be well north of 70k.
Col. Brain is offline   Reply With Quote
