JUICEDMOTORSPORTS
Old 06-01-2013, 11:42 PM   #1
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
Your experience w/ nitrous.
I am going to have the Zex nitrous system installed, this is an automatic system that kicks in @ wide open throttle (WOT). Does anyone have this system or one similiar that can tell me about it? I have a M6 transmission.
When you floor it and the nitrous kicks in I would think the RPM's would increase to the red line almost instantly making you have to back off of the throttle, is that how it works? It would seem like you wouldn't be able to shift fast enough to keep from red lining. What kind of feel is it when the nitrous opens? I want that "push me back in the seat" feeling where you can really feel the G's. How about sound, is there any sound difference when the nitrous opens?
If you have a purge system where did you mount the purge nozzle? If you have any advice please lay it on me.
Russ
OHIOSS is offline   Reply With Quote
Old 06-02-2013, 04:48 AM   #2
OHIOSS
Russ
No comment?
Doesn't anyone have nitrous?
Old 06-02-2013, 06:21 AM   #3
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
Originally Posted by OHIOSS View Post
No comment?
You might get more answers in the nitrous subforum.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 06-02-2013, 07:04 AM   #4
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15 STI, EB Expy,'10 2SS/RS M6, KB1
Read the nitrous sticky under the FI section. Window switch in conjuction with wot or tps will keep you spraying at the correct rpms. Wet or dry kit? Plate or nozzle? Not sure what Zex offers. Your current mods? G's, depends on how big of a shot. Which depends on your level of traction, your ability to supply fuel and how you tune. Sound? What's your current exhaust? Through mine, it sounds more "mean".
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 06-02-2013, 09:25 AM   #5
bbbang
Drives: 2011 Camaro 2ss/rs ls3
You should consider contacting Nitrous Outlet for your system they have great products and customer service.
bbbang is offline   Reply With Quote
Old 06-02-2013, 09:43 AM   #6
cybergrayls3
Drives: 2010 camaro 2ss/rs..m6..CGM
i had a harris speed works kit on my 4th gen camaro..the rpms dont just shoot to redline..i was only spraying a 100 shot on a cam/bolt-on/stalled ls1..i used the 150 shot a few times but it didnt seem to pull that much harder then the 100 shot. Its not like fast and furious where you hit the nitrous and suddenly everything around you turns green and purple and gets blurry haha. I mean if your car makes around 370rwhp stock..and you spray a 100 shot..its gonna feel like a car with approx 470 rhwp. So any camaro out there with around that horsepower will feel very similar..nitrous does usually produce very good torque numbers...it also depends if your kit is a progressive hit or just on or off..this will obviously make a difference in how hard it pushes you back.
-Lethal Racing NF cam
-Kooks LT's/high flow cats
-Borla ATAK catback
-CAI cold air intake (black)/Apex scoop
-LSR shifter
-Rick Crawford intake manifold
-Monster level 3 clutch
cybergrayls3 is offline   Reply With Quote
Old 06-02-2013, 10:46 AM   #7
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Most peoples experience with nitrous:
WEEEEEEEEE!
then:
KAAABOOOOOM!
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 06-02-2013, 11:29 AM   #8
62nalide
62nalide's Avatar
Drives: 2013 SS
WEEEEEEEEE!
then:
KAAABOOOOOM!
Lol you mean most people that doesn't have a clue what there doing. Been spraying a 4.8L with a 150 for 3yrs and still kicking been through 20 bottles
10.45 @ 130mph all motor
GPI everythang!
Aka MR. NightFury Killer
62nalide is offline   Reply With Quote
Old 06-02-2013, 12:28 PM   #9
drayco513
drayco513's Avatar
Drives: ss2/rs
i run the hsw 90mm plate kit , lnc2000 timing box/s step, and nos launcher progressive box. its not gonna just go to red line instantly but it will make it a lil fast then it is now. but nothing to worry about. run a window switch cause if u miss shift or over rev. with just w.o.t. switch car cuts fuel . keep spraying nitrous and u got urs self a backfire. then just hope it blew the filter off ur intake or blew apart the intake manifold. also run br7ef plugs. + the best fuel u can find . for insurance. its not required but i would rather pay a lil for fuel and be safe then buy a engine . if ur tuning ur car for nitrrous do it by the plug check ur plugs often . start with pulling 1 degree of timing for ever 25 shot to start with and go from there.
also if u gong to buy a kit go nitrous outlet by far the best nitrous company out there. great guys. will help u any way they can .
461/423 n/a
drayco513 is offline   Reply With Quote
Old 06-02-2013, 01:03 PM   #10
willhe64
willhe64's Avatar
Why is it always the nitrous cars exploding at the track? Doesn't matter how good you are with it. Fact is everything has to be perfect or it blows. Still the riskiest power adder there is period.
Old 06-02-2013, 01:16 PM   #11
62nalide
62nalide's Avatar
Drives: 2013 SS
Riskiest? Try playing with turbos now thats a risky power adder just pray for it not to boost spike. It is all in the tune and on your setup like I said going on 3yrs with a 4.8L 150shot and drives like a champ. A wideband helps you keep an eye on things. Most people add lets say 100shot untuned and stock plugs, runs good but not recommended. If your scared to play with nitrous then just don't at all but if you understand how it works go for it heck even stock LS1s have taken a 200shot bone stock and last of course with a lil meth to steam clean your motor
GPI everythang!
Old 06-02-2013, 01:18 PM   #12
62nalide
62nalide's Avatar
Drives: 2013 SS
Also I'm not saying it'll last forever just know what your doing for it to last long
GPI everythang!
Old 06-02-2013, 01:55 PM   #13
drayco513
drayco513's Avatar
Drives: ss2/rs
thats the price tho for the best power adder. nitrous over blowers anyday. for raw power
461/423 n/a
Old 06-02-2013, 01:56 PM   #14
drayco513
drayco513's Avatar
Drives: ss2/rs
as the case with anything u mod if u cant afford to buy another engine it best not to mod at all.
461/423 n/a
