SDTW Custom Wheels & Tires
Old 06-02-2013, 03:06 AM   #1
sswiss3000
sswiss3000's Avatar
Drives: 2012 Camaro 2SS Vert, L99
2012 Camaro SS Convertible Suspension
Which suspension does the 2012 Camaro SS Convertible have? Is it the FE3 or 4? I believe the 2012 Coupe has the 4 but the convertible stayed with the FE3, correct?
Also, which year ZL1 sway bar can I upgrade to?
sswiss3000 is offline   Reply With Quote
Old 06-02-2013, 02:08 PM   #2
Chevrolet Customer Svc
Drives: GM Vehicles
Greetings sswiss3000,
The 2012 Camaro SS has the FE3 performance suspension, which comes standard on the SS Convertible. And yes, the FE4 is standard on the 2012 SS Coupe.
I hope that helps,
William R.
Chevrolet Customer Care
Old 06-02-2013, 02:17 PM   #3
pannhead51
pannhead51's Avatar
Drives: 2SS convertible
I'm not all that impressed with the factory suspension, seems sloppy in the turns.. will be looking into aftermarket sway-bars soon.
pannhead51 is offline   Reply With Quote
Old 06-02-2013, 02:34 PM   #4
Top Off
Drives: 2012 LS3 1SS/RS Vert
My problem is trying to put power down in the corners.
QUOTQUOTE=pannhead51;6619212]I'm not all that impressed with the factory suspension, seems sloppy in the turns.. will be looking into aftermarket sway-bars soon.[/QUOTE]
Top Off is offline   Reply With Quote
Old 06-02-2013, 06:14 PM   #5
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
ZL1 rear sway bar bolts right in. You'll need the bar and new sway bar links. The holes are already in the lower arms. For the front you can use either the ZL1 or the 1LE. Again you'll need the sway bar and new links. Where the links attach at the upper end you will need to enlarge the hole to accomodate the larger end link.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 06-02-2013, 06:28 PM   #6
pannhead51
pannhead51's Avatar
Thanks
Old 06-02-2013, 09:38 PM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Once you've upgraded you can feel the difference. Switching to a better tire will also help with cornering. Also, just a suggestion, while you're switching the sway bars, you might want to swap out the trailing arms and tie rods.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 06-02-2013, 10:37 PM   #8
sswiss3000
sswiss3000's Avatar
Chris82xx, I am kind of a newbie on suspension upgrades. what kind of benefits can I expect from replacing the trailing arms and tie rods? Also, what would you suggest replacing them with?
Old 06-02-2013, 10:51 PM   #9
Chris82xx
Chris82xx's Avatar
Trailing arms and tie rods will help improve traction not only in launches, but also in cornering. It provides more stability. Brand? Well, that one is open to public opinion. There are quite a few companies that sell suspension parts. I chose to go with Pfadt because the shop that I use is mainly familiar with their products so for me it just made more sense.
811RWHP/719RWTQ
Old 06-02-2013, 11:47 PM   #10
camaro2lt
camaro2lt's Avatar
pedders sway bars helped my coupe....went on a drive today on some winding roads and in a 25,mph corner i can take them at 50mph and feel very planted
