Old 06-02-2013, 08:48 AM   #1
larietrope
Drives: 1970 Boss 302
L99 vs LS3 eternal question
Considering a look at the 2013 SS now that the year is up. No factory upgrade exhaust for L99 it's for manual transmission cars only ?
How do you you "tune" out the variable valve timing on automatics and is it a performance increase or just a convience ? What exhaust system will benefit the L99 and still not drone ? What about the lifter issue ?
If I go with the LS3 is the short throw shifter worth it ?
Also, is the fuse pull issue over for 2013 L99 cars ?
Thanks.
larietrope is offline   Reply With Quote
Old 06-02-2013, 10:54 AM   #2
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
If you get an ls3 you should really try the "long throw shifter" it really gives the car that "retro " feel.
Mchlgrrsn is offline   Reply With Quote
Old 06-02-2013, 02:44 PM   #3
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
Thanks.
The build your own on Chevys website lets me put the performance exhaust on an auto so I think that won't be a problem. I don't know why you would tune out vvt - it helps build better low end torque and doesn't pose any significant problems. People tune out the DOD or AFM to keep it running on all 8 all the time. This makes a huge difference and is very nice to have done. Can be done by a professional or with a handheld but will void warranty. Corsa seems to be drone free but you can add j pipes to kill drone on just about anything it seems, or just shift to stay out of that rpm range. I haven't heard of a lifter issue necessarily but if you plan on going with a cam upgrade you can do an LS3 conversion which will swap the lifters and physically remove the vvt and afm parts. The fuse pull is a low risk quick fix and really isn't anything to worry about. Just do it and don't put in regular. I don't know anything about the short throw shifter.
I tried to address everything to the best of my knowledge, you can reach out to any sponsor on here with any question regarding the mods you want to do and they can probably tell you if the LS3 will respond better than the L99. Ultimately, think about how you plan to use the car - if it will be a dd, do you want to deal with a manual in heavy traffic daily? If it is just for cruising would you miss the feel of a manual? Both engines are capable of insane power and can be very fun to drive you can't go wrong.
RolltideSS is offline   Reply With Quote
Old 06-02-2013, 02:50 PM   #4
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 06-02-2013, 05:21 PM   #5
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
The long throw shifter delivering that "retro" feel. Designed to work with shorties and K&N intakes
Old 06-02-2013, 05:23 PM   #6
mikeyg36
mikeyg36's Avatar
Please stop I'm dying...
Old 06-02-2013, 05:28 PM   #7
midnighter
Drives: nothing
That's a looooonnnng ass shifter like on a 1990 Ford F250 manual.
Old 06-02-2013, 05:36 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Attachment 517931
Can I rig up some naws to the black pull?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-02-2013, 06:32 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Lmao! You clowns
