HeadlightArmor
Old 06-02-2013, 10:08 AM   #1
BossSauce
BossSauce's Avatar
Drives: 2012 Camaro SS / Summit White
Oil Pressure Question
What is the normal Oil Pressure levels for idle and while driving?, I noticed my oil pressure drop today while I was idle in traffic for like 10 minutes it was below 30, then it went up as I accelerated It was on the line after 30. I never noticed this until today, Is this normal for the SS?
BossSauce is offline   Reply With Quote
Old 06-02-2013, 11:03 AM   #2
james347
Drives: 2006 Crownline
At idle, mine sits around 30, maybe a little under. Under acceleration it moves up to between the 30 and whatever the high mark is. 60ish? In other words, sounds normal.
james347 is offline   Reply With Quote
Old 06-02-2013, 11:14 AM   #3
BossSauce
BossSauce's Avatar
Thank you man, I can rest easy now.
Old 06-02-2013, 11:51 AM   #4
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Depends on how hot the oil is, a little under 30 when hot at idle and around 35 or so cruising and around 60 when nailing it.
Scott@Bjorn3D is offline   Reply With Quote
Old 06-02-2013, 11:59 AM   #5
dollar14
dollar14's Avatar
Drives: 2010 summit white 2SS/RS M6
that sounds normal for 5w-30 oil.but if your gonna beat on these things and especially if your forced induction,my motor guy says 15w-50.thats what I run and carry about 10 lbs more than that.
2010 2SS/RS M6,kooks 1-7/8 LT'S with hi flow cats,factory NPP cat back system,ADM performance street c.a.i.ADM built LSA with 750+ package,160 deg. thermostat,mti six shooter shifter,jac fab front license plate bracket and tunnel brace,eibach 1 inch pro kit,ADM exhaust controller,custom ADM performance tune,703 rwhp 704 rwtq
dollar14 is offline   Reply With Quote
Old 06-02-2013, 12:10 PM   #6
BossSauce
BossSauce's Avatar
This is good information guys, I will read up more on this. I'm so glad this is normal operation being that my car has less than 4000 miles on it, I was worried I had a problem with the car. Thanks guys.
