Old 06-02-2013, 01:23 PM   #1
jkof08
jkof08's Avatar
Drives: Black 2SS/RS
How Much Power does my set up have.
i have 2010 A6 SS. stock 340 RWHP with a Hennessey CAI 15+ RWHP, Diablo Tuner with a 93 tune 25+RWHP Flowmaster Pro Series Axel Back 10+RWHP. these gains are all what was advertised. i want to know what i really have. i know go to a dyne but im not going to be doing that for a while so what do yall think. My friend has a 2007 Roush 427R with 550 HP dyno'd i need to know what i can get to beat him at the track. a cam is not an option. i was thinking a TSI Torque converter, Ported Throttle body, Headers, high flow cats, and Tune.
C.A.I. CAI, FlowMaster Pro Series, 1LE Strut Brace, Ported Throttle Body, Vengeance Tune, JRE Scoop, MSD Wires, 3.70 Gears, Stainless Works LT Headers and Hi Flow Cats, Pro Torque 3500 stall, LS3 Conversion Stage 2 TSP Port & Polished Heads, Kaotik CAM. 18x10 Forgestar F14 wrapped in 305/45/18 MT Street ET II's
12.068 @ 119.9 1.9 60ft (on 20' DR's with a VVT CAM)
jkof08 is offline   Reply With Quote
Old 06-02-2013, 02:09 PM   #2
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
I have LT stepped headers, borla exhaust CAI intake and was at 370 rwhp after my tune two days ago. Keep in mind a tune is really only good for a specific car on a given day - temperature, humidity and altitude will impact it. The exhaust is effectively a wash in these cars, and they start around 320 rwhp, there is an l99 dunno thread that shows this consistently. To get to 550 hp you are probably looking at Forced induction and a cam. I would recommend talking to a local fast shop or one of the sponsors and set up a plan to figure out what you need to meet your long term goals.
RolltideSS is offline   Reply With Quote
Old 06-02-2013, 02:14 PM   #3
Camaro54
Camaro54's Avatar
Drives: Camaro SS2/RS orange/black stripes
IMHO you need more than you're probably willing to go. Most 2010 A6 SS are closer to 325 rwhp. That's what mine started off at. Add the other 50 HP and that would have you minimum 375 rwhp which may be closer. With your extra weight you need to add 200 rwhp which will be about 250 at the block. That would then have you minimum setting at 575 rwhp which you'll at the least need to compensate for being 300 lbs heavier. Do headers/blower/spray/$10,000. I know. It's expensive but fun.
2010/2SS/RS/6L80E/Mast built LS3 416 Stroker/Black Lable Heads/Blower Cam/Jannetty Tuned/ 685rwhp/635tq/KookHeaders/3"exhaust/Magnaflows/Whipple Blower/10lbs bst/Duel pumps/85lb inj/2 gauge pillar/CAI/RX catch can/Vmax ported TB/Lexani LX15s/Pedders sub F bushings inserts/Pedders sport extreme coilovers/ZL1 sway bars/Hotchkis strut tower brace/Hawk brake pads/stainless steel brake lines/CTV front calibers/slotted rotors 15"/1 pc drive shaft & loop/hidden radar-laser detect/rear louvers/terminator hood/ SS mats/black outs/Bowties/GM GFX kit/blade spoiler/deading matting/wolf art/
Camaro54 is offline   Reply With Quote
Old 06-02-2013, 02:23 PM   #4
62nalide
62nalide's Avatar
Drives: 2013 SS
A diablo tuner is pretty much good for 12rwhp I say go with your thinking mods, that'll help. I see you have 21s those wheels are too heavy some lighter wheels and drag radials you might have a better chance
62nalide is offline   Reply With Quote
Old 06-02-2013, 02:29 PM   #5
Demon Z/28
Scarecrow
Demon Z/28's Avatar
Drives: like a granny
You need a supercharger. Since a cam is out, that's your only option. Cam and headwords would do the trick though.
The Rooster - 2015 Z/28
The Scarecrow -2014 1LE SOLD -
Demon Z/28 is offline   Reply With Quote
Old 06-02-2013, 02:29 PM   #6
Birm
Birm's Avatar
Drives: Florida Speed & Power
Suspension upgrades to actually put your power down.. Lose the 21" wheels maybe go to a more track friendly size and an appropriate tire
Birm is offline   Reply With Quote
Old 06-02-2013, 07:27 PM   #7
cybergrayls3
Drives: 2010 camaro 2ss/rs..m6..CGM
long tubes,200 shot,torque converter,gears,slicks and skinnys
-Lethal Racing NF cam
-Kooks LT's/high flow cats
-Borla ATAK catback
-CAI cold air intake (black)/Apex scoop
-LSR shifter
-Rick Crawford intake manifold
-Monster level 3 clutch
cybergrayls3 is offline   Reply With Quote
Old 06-02-2013, 07:42 PM   #8
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Mustang Dyno: 345-350hp, Dynojet: 360-365hp
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 06-02-2013, 08:07 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Op you are using ricer math.
It doesn't work that way, search the L99 dyno thread and see. Stock your about 320-335 depending on the dyno they are all different.
With Lt's you'll be in the 370-390 hp (dyno tuned) of course.
A TQ converter from Yank or pro torque are good brands that will pay dividends at the track. Not to mention a good Trans tune! But if he's putting down that much do some hot laps and on the 2/3rd run you'll get his heat soaked azz lol or wait til next month when it's the hottest lol. Good luck.
Old 06-03-2013, 12:28 AM   #10
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
To get close to 500whp on a L99, you'll need a cam and heads, or FI of some fashion, or a very health shot of nitrous. No other way to come even close. With all the bolt-on possible, you'd be lucky if you hit 400whp.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-03-2013, 12:46 AM   #11
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
Definitely all the bolt ons you can afford and then some...
Suspension mods
Gearing (not sure what your options are at the moment)
18" wheels will help, with some wide stickies in the rear.
Track time and experience
TUNE fo sho
Your going to need every advantage you can get since your limiting yourself.
And some times you just have to face the fact that you aren't the fastest car on the block.
And why are you willing to install a converter but not a cam?
hapisok is offline   Reply With Quote
Old 06-03-2013, 06:35 AM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
^^^ where you been?^^^ I missed you head over to the v8 lounge foooo!
Old 06-03-2013, 09:18 AM   #13
jkof08
jkof08's Avatar
Suspension mods
TUNE fo sho
well i like cams and more than likely i will get one but at the moment i let my wife drive the car when she wants, its her dream car other than an R8 lol but she really doesnt like the lopy sound. but to get low mid 12's i was thinking of doing headers, PTB, converter, 20' ZL1 Rims and 285 all the way around eibach lowing springs and sway bars, tune, catch can, and 3.70 gears.
