Cold Air Inductions
Old 06-02-2013, 03:44 PM   #1
Meister
Meister's Avatar
Drives: 2016 Corvette Stingray Z51
Mild 2 Wild on 2013 SS
Those that have installed the M2W exhaust controller on their 2013 SS Camaros. Did you follow the special instructions for the ZL1 installation? I am just a little confused by this one. I didn't do the ZL1 type install and I ended up with a "parking assist" error. Any help would be appreciated.
Meister is offline   Reply With Quote
Old 06-02-2013, 07:17 PM   #2
Meister
Meister's Avatar
Anyone?
Old 06-02-2013, 09:11 PM   #3
Meister
Meister's Avatar
http://www.nakidparts.com/sitebuilde...les/m2wzl1.pdf
These are the instructions I was speaking of. Surely someone out there has this on their 2013 SS?
Old 07-08-2013, 10:49 PM   #4
RonnieG
RonnieG's Avatar
Drives: 2013 AGM 1LE/2SS/RS
can't believe no one's said anything here.. hopefully you got it figured out.. I'm having this same issue as instructions didn't come with my M2W and all i can find online are the "ZL1 instructions". If you remove the ZL1 mod then you don't have that extra white wire sticking out to plug into the red fuse spot, and it seems weird that you would just plug the fuse into the radio fuse area.. i finally have time to do this mod and I'm not sure what to do with these ZL1 instructions =/
RonnieG is offline   Reply With Quote
Old 07-08-2013, 11:49 PM   #5
Meister
Meister's Avatar
Use the ZL1 instructions for the SS. Could have been clearer in the instructions. Once I figured that out it worked fine.
Old 07-09-2013, 12:06 AM   #6
SPCBA
Drives: pleather and Chiclets
Ryne Cunningham has a vette version on his 1LE...
SPCBA is offline   Reply With Quote
Old 07-09-2013, 03:38 PM   #7
Meister
Meister's Avatar
Follow the instructions from the link in post #3 of this thread and do the ZL1 version.
