JDP Motorsports
Old 06-02-2013, 07:53 PM   #1
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
Meth/Chiller question
If I`m running a meth system do I really need a super chiller? What do they cost?
2013 Red ZL1 Auto modded
2015 C7 ZO6 Luguna Blue stock
BeardWS6 is offline   Reply With Quote
Old 06-05-2013, 03:32 PM   #2
Matt@510
Drives: c6 vette cam & full bolt-ons
A chiller system is not needed. it could help especially here in texas. anything to help cool the air going in the motor will certainly help. what other mods do you have besides the meth kit? have you upgraded the heat exchanger?
Matt@510 is offline   Reply With Quote
Old 06-05-2013, 03:43 PM   #3
SC2150
Since you asked for the price, we can post it. $899 for the RX system.
We quite often use both meth with the chiller, but you can add as big of a HE as you want and your still dependant upon ambient air temps, and the added weight. A good sized coolant tank is a must, but with the RX superchiller, we are cooling your HE coolant temp down 30-50-60* F below ambient air temp so there is no other way to get it that cool, and keep it that cool.
In the old days with heads up FI cars we would put 100-200#'s of ice in a tank in the trunk, but it only lasted 1-2 runs and every 100# is app a tenth in the 1/4 mile. The chiller works best in desert low humidity climates and is cooling at all times to reduce fatigue on the blower and other components as well as allowing full timing advance. Then when you go to the track, flip the competition mode switch and the cabin AC turns off so no moisture is extracted from the cabin air to drip on the track, and all Freon is diverted to the chiller for even more cooling.
Just watch the video:
Old 06-05-2013, 07:50 PM   #4
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
1. Roto Fab Cold Air Kit
2. ZL1 Custom Heat Exchanger with dual fans
3. Metco Motorsports 9.1" lower pulley ( includes innovators west damper)
4. Metco Motorsports 2.5" blower pulley
5. Cam specs 227/242/520/590/122+6.
6. .675 lift double valve spring kit with Ti Retainers
7. Comp cam pushrods
8. 160 degree thermostat
9. solid isolater
10. Kooks 1 7/8" headers with Catted Connection pipe
11. Metco 50 MM Idler pulley
12. Blower belt
13. Ported mouth, ported blower, snout, throttle body
14. MSD wires and NGK TR7IX spark plugs
15. Alky Control Meth injection kit
16. ID 850 fuel Injectors
I`m making 705rwhp 694trq at the wheels with a auto. I`m still stock block and heads for now.. Car runs like a beast..
Old 06-05-2013, 08:43 PM   #5
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Those are awesome numbers if that is on a safe pump gas tune!
Trackman is offline   Reply With Quote
Old 06-06-2013, 08:19 PM   #6
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
Yes, the car is amazing bro!
Old 06-06-2013, 09:39 PM   #7
SC2150
VERY impressive!!!
Old 06-08-2013, 05:43 PM   #8
bumblebeecamaro
Car Lover By Nature
Drives: Mini Cooper S
I had a chiller on my Maggie SS but then it developed a small leak around one of the o rings. I then had to drive all the way to the St Pete area which is roughly a two hour, one way drive for me. The installer fixed the leak but I just had him put the car's A/C system back to stock. Having the system was nice but it wasn't worth trashing my car's A/C system's warranty.
bumblebeecamaro is offline   Reply With Quote
Old 06-08-2013, 05:51 PM   #9
thespymaster
thespymaster's Avatar
This is my next MOD for sure!
Old 06-09-2013, 08:14 PM   #10
the rich dude
Drives: Getting 2010 Camaro
9. solid isolater
12. Blower belt
is that with the stock fuel pump?
also did u do any dyno numbers without the meth kit?
the rich dude is offline   Reply With Quote
Old 06-09-2013, 08:18 PM   #11
the rich dude
VERY impressive!!!
whats involved with installing the super chiller?? I'm guessing a a/c guy needs to do the install? thanks
Old 06-09-2013, 08:38 PM   #12
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
Stock fuel pump, I didn`t think to get them to dyno without the meth kit. Mike said if I do heads I need to get a fuel system with it also. I see no reason for heads since it`s a low 10`s car already and it`s tough to hook up even with the 315 nitto`s. But she is amazing to drive, just like stock until you drop the hammer! Then the Beast comes alive..
Old 06-09-2013, 10:47 PM   #13
Trackman
Trackman's Avatar
You should post your low 10 time slip and get added to the fast list.
Old 06-09-2013, 10:52 PM   #14
Supercharged SS
Drives: 2010 Camaro
Ha, yeah, no shit. Everyone and there cousin with a 700 HP car says it goes 10's. It doesn't go low 10's until it actually goes low 10's!!
