BORLA
Old 06-02-2013, 08:30 PM   #1
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: Black 2010 2SS/RS M6
HELP! Service StabilTrack and all lights going off including ABS.
Hello...I'm in the process of taking my differential out and can't get the driver side axle out of the pumpkin! Any suggestions? I followed the pfadt instructions!
http://www.pfadtracing.com/blog/wp-c...ation-reva.pdf
Thank you in advance.
Got the install done!
NOW
All indicator lights are going off...it says Service Stabiltrack.
Is this because the Speedo Calibration is off and the computer is finding that Problem? Will a tune to fix the speedo calibration help. Planned on getting one ASAP!
Any Help will be greatly appreciated.
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 06-02-2013, 08:46 PM   #2
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
turn the CV housing as you are tapping the outer edge, the internal snap ring sometimes will get stuck and not let itself compress. by tapping it as you turn it will let it move a bit and then try prying again.
Driveshaftshop is offline   Reply With Quote
Old 06-02-2013, 09:05 PM   #3
BRAVO 2SS
BRAVO 2SS's Avatar
Yup...that was it...THANK YOU!
But now the damn Service light came on.
The check engine light is from my Rear O2 sensors from my LT Headers.
2010 Camaro 2SS/RS
Old 06-03-2013, 01:59 AM   #4
BRAVO 2SS
BRAVO 2SS's Avatar
Pic
2010 Camaro 2SS/RS
Old 06-17-2013, 08:09 PM   #5
BRAVO 2SS
BRAVO 2SS's Avatar
Ok...so I just got back from synergy motorsportsts for my tune.
The speedo is recalibrated and the check engine light is off.
But the ABS light is still on along with Service stabilitrack and traction control and the nannies button does nothing.
So I ordered a new speed sensor wire because I know some members have broken them even though the exterior wire is connected and looks fine...hopefully this will work.
As I was leaving...the park assistant light said to service park assist and my Brake light is on and the Emergency brake seems to have less tension when setting it. Any ideas???
Can the dyno make the E brake line tear or break?
I'm lost...help please!
2010 Camaro 2SS/RS
Old 06-17-2013, 09:16 PM   #6
camaro34
camaro34's Avatar
Drives: 2011 Camaro SS
It sounds like it could be a wheel speed sensor. You can test it with a DMM, it should put out about 5 volts when the wheel is spinning.
camaro34 is offline   Reply With Quote
