BORLA
Old 06-02-2013, 11:28 PM   #1
Jamesdman24
Drives: 1969 camaro, soon 2012 ZL1 camaro
ZL1 Rear end noise
I have a 2012 ZL1. The rear end makes this weird humming noise, similar to the sound when your power steering is low, coming from the rear when the wheels are cranked in either reverse or forward. Any help would be great!!!
Jamesdman24 is offline   Reply With Quote
Old 06-03-2013, 05:13 AM   #2
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
Same here when she is cold. Once heated up it goes away! 2013 ZL1
2013 Red ZL1 Auto modded
2015 C7 ZO6 Luguna Blue stock
BeardWS6 is offline   Reply With Quote
Old 06-03-2013, 09:00 AM   #3
Rizzo
Drives: 2012 Camaro ZL-1 SIM
I had the same issue. I found the TSB that relates to the issue that the SS has and the dealership honored the work. They replaced the fluid in the rear diff and also changed out the seals (per the TSB).
Since then, I haven't had the sound reappear. I think GM should look at extending the TSB to officially support the ZL1 as well.
Rizzo is offline   Reply With Quote
Old 06-03-2013, 11:49 PM   #4
CROWN
Drives: Customer's Projects
theres a private bulletin for the zl1's. Calls to flush the fluid about 3 times and in between those drive it so many miles doing so many figure 8's and a lot of nonsense, all in all majority of the time they are replacing the whole rear end, and when you get it supose to take apart the cover and brake clean inside to get the paint off. The paint they used inside on the gear in the differential to set it, isn't breaking down like its supose to contaminating the lsd.
Karl Performance
Des Moines, IA
AWD Chassis dyno
EFI Tuning
CROWN is offline   Reply With Quote
Old 06-04-2013, 01:33 AM   #5
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
Do you have the tsb# ???
Laus Deo
charlietuna is offline   Reply With Quote
Old 06-04-2013, 12:16 PM   #6
ZL1Catfish
ZL1Catfish's Avatar
Drives: 2013 Camaro ZL1
Im interesyed in thos also. I also notice some sort of loud winning noise espesially in 4yh or 5th gear. Dont recall as im giving it gas.
HRE Monoblocks 20inch wheels, Roto-fab CAI, ZL1 Borla S-type, tinted windows
ZL1Catfish is offline   Reply With Quote
Old 06-04-2013, 12:32 PM   #7
Al C.
Al C.'s Avatar
Drives: ZL1 #529 "El-Jefe"
Just change the fluid, it will go away! takes 20 mins to do. you have to get the diff fluid with ls additive already in it.
Al C. is offline   Reply With Quote
Old 06-04-2013, 01:00 PM   #8
DangerZL1
Drives: Future ZL1 Owner
May not be related to the fluid issue. Could be improper lash setup in the rear. Changing fluid will not help this problem.
DangerZL1 is offline   Reply With Quote
Old 06-04-2013, 01:23 PM   #9
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
When changing the fluid, how do you flush the old fluid out of the lines and cooler going up to the front?
Th3Beast is offline   Reply With Quote
Old 06-04-2013, 01:34 PM   #10
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
I had this issue, dealer changed out the fluid and the problem went away.
Modern07 is offline   Reply With Quote
Old 06-04-2013, 02:42 PM   #11
Al C.
Al C.'s Avatar
I just drained at the diff, and filled at the upper plug, noise stopped. If you feel draining at the diff is not good enough and want to get the lines and cooler drained, take it to the dealer. Im sure they use some sort of positive feed pump, but i dont think thats needed.
Old 06-04-2013, 05:49 PM   #12
DangerZL1
Draining the lines and cooler would have no effect on the noise. The cooler is running transmission fluid and doesn't mix with the rear diff fluid.
Old 06-04-2013, 11:31 PM   #13
Jamesdman24
Thanks guys. Sounds like my dealership is changing my fluid!!!
Old 06-05-2013, 08:46 AM   #14
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
Correct me if I'm wrong, but if there is a feed and return line going from the diff to the front of the car and ran thru a heat exchanger, than there will be old gear fluid in those lines and hx unless flushed.
