Old 06-03-2013, 01:59 PM   #1
m79z28
Drives: 1979 Z28 w/LFX
LFX Fuel Pump Help-Mod
Putting a 2012 LFX into my '79 Z28. Yes, you read right and, no, I could care less if you feel its sacrilege
Since it is the LFX, it seems more difficult to find aftermarket parts. I'm currently hung up on finding an external fuel pump. The dealer here won't offer any info on what is stock (I'm guessing stock is internal) or any other details. I'm finding nothing on a google search and local performance houses don't seem to have much info either.
I have the stock fuel pump ecm. From what I understand, I will be running just a single fuel rail.
Any help is greatly appreciated!
m79z28 is offline   Reply With Quote
Old 06-03-2013, 02:07 PM   #2
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
You have two fuel pumps. There is the lift pump that is in the gas tank and the high pressure pump that runs off one of your cams. The high pressure pump feeds two fuel rails, one for each bank.
If you bought a take-out salvage motor then you should have the fuel rails and high pressure pump. You can get the in tank pump from a GM dealer. Just ask them for an in-tank pump for a 2012+ LFX engine.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 06-03-2013, 02:10 PM   #3
m79z28
I'm fairly sure the cam pump is in tact, it is the tank pump I'm trying to figure out.
I'm putting it in my 1979 Z28 so the in-tank pump won't work with the configuration. Looking for any technical specs or leads to find an external pump that will work.
Old 06-03-2013, 02:13 PM   #4
GretchenGotGrowl
Hit up Rhino79 with a PM and I'm sure he can give you the gal/hr and pressure specs.
Old 06-08-2013, 06:40 AM   #5
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The LFX pump is the same as the SS pump. For the LFX you could use any pump really that was around 255 lph ( wouldn't really need that much but would give room to grow with more power). Then you could use the c5 corvette fuel filter/regulator assy.
Rhino79 is offline   Reply With Quote
Old 06-10-2013, 10:10 PM   #6
Airmaster
Go Gators!
Airmaster's Avatar
Drives: '13 Camaro '12 Abarth '97 Wrangler
That project honestly sounds bad ass. Let us know how it ends up for sure!!
Airmaster is offline   Reply With Quote
Old 12-30-2014, 10:00 PM   #7
67-LS1
Drives: 1966 Chevelle
I guess I'm bringing this post out of hibernation....
I am putting a 2013 LFX inti my 1966 Chevelle and I am also at the point of needed to decide on an external fuel pump and regulator.
M79Z28, what did you end up doing and how did if workout?
Thanks,
Dennis
67-LS1 is offline   Reply With Quote
