Solo Performance
Old 06-03-2013, 07:39 PM   #1
Camper
Banned
Drives: 10' 2SS LS3 M6
@litle88, best intake?( ok..not really, but come look!)
hahahahaha, tricked ya! Check out the ride I just picked up to split time with my 5th gen lol.
- Stock LQ9 6 liter short block has
- Ported LS3 heads with PRC EHT .675" springs
- ARP Bolts
- all Gaskets replaced
- LS7 lifters
- Hardened pushrods
- New LS6 oil pump
- TSP 231/236 .641''/.615'' LS3 cam.
- LS3 intake with a edelbrock 90mm tb
- Under drive crank/alternator pulley
- New AC system
- New Serp Belt
- New ac tensioner
- New Katech manual tensioner
- New idlers
- Electric fan over ride switch
- SLP air lid
Exhaust
- TSP 1-7/8" ceramic coated headers
- duals into a bassani x pipe into a 3" Y into a 3" magnaflow
Transmission
- New Hughes TH400 34-3x w/brake w/reverse manual valve body
- New hughes pro series 8" converter w/anti ballooning plates, 4k stall
- Trans cooler w/ -6 line
- Stock shifter
Rear
- New quick performance 9"
- nodular center section w/3:25 gear
- spool
- Daytona pinion support
-1350 yoke
- Custom 3" drive shaft
- Drain plug
- Fill cap
- Adjustable relocation brackets built into rear end
There is no ABS on rear end, I do however have all factory parts if one wants them including the stock SLP rear end.
Chassis/Suspension
- UMI K member
- UMI tubular front upper and lower control arms
- adjustable QA1 coilovers up front
- UMI solid motor mounts
- UMI 3 point sub frame connectors
- UMI tunnel mount torque arm
- BMR on car Double adjustable panhard bar
- UMI Rear adjustable control arms
- New 10 way single adjustable strange shocks
Wheels/Tires
- 3" extended stud all 4 corners
- New Weld Drag Lites
- ET Street radial 275/60/15 in the rear
- 26/7/15 MT radial front runners.
Brakes
- Front and rear new cross drilled and slotted rotors
- Front and rear new brake pads
Fuel
- Racetronix pump
- Racetronix hotwire kit
- stock injectors
Nitrous ( not operational )
- 90mm nitrous outlet plate kit 50-400hp or Shark Nozzle
- Edelbrock noids
- -6 long line
- 10lb bottle
- standalone tank
Camper is offline   Reply With Quote
Old 06-03-2013, 07:39 PM   #2
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 06-03-2013, 07:44 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You SOB!!!
That's a clean azz and rare color!!!
Old 06-03-2013, 07:47 PM   #4
Motion427
Drives: 2010 2SS/RS Red Jewel L99
That's a nice setup you got there.
Ran it at the track yet?
Motion427 is offline   Reply With Quote
Old 06-03-2013, 07:48 PM   #5
Camper
Banned
little low on power but probably has 10s in it as it sits on motor. Dont care for the nitrous setup that he was trying to get rolling, just gonna rip it out until I get all the parts I want ( progressive,window switch,etc.)
its extremely clean though and am absolutely amazed at how clean it is in/out. Its honestly just what I was looking for, something built with a somewhat low HP motor.
price was to good to pass at least I think so, I know what it costs to racecar mod.. he was asking 14,500 and ended up with it for 12,500
Old 06-03-2013, 07:49 PM   #6
Camper
Banned
going to pick it up right now. Has a slight pump issue, dropped to 40psi on the dyno saturday. Getting the pump replaced wednesday.
Old 06-03-2013, 07:50 PM   #7
Birm
Birm's Avatar
Drives: Florida Speed & Power
That thing is B.A.!
Birm is offline   Reply With Quote
Old 06-03-2013, 07:54 PM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Hey DC that BBM color was on only 1117 Camaros. It's badazz! For sure, bring it down here so it can get that Chitown touch! Lol we'll run it down here too lol.
When I saw the thread I'm like great ANOTHER stalker! Lol
Congrats DC! Good find!
Old 06-03-2013, 07:59 PM   #9
Camper
Banned
when I get tired of NA, maybe ill take it to turbo joe and throw something at the iron block. Doesnt need much power on the setup for dig runs.
Old 06-03-2013, 07:59 PM   #10
Motion427
You can't built it for that $$$$$$.
Old 06-03-2013, 08:03 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Get a racetronix pump with a Hotwire kit and will have the harness for a plug and play BAP.
Old 06-03-2013, 08:03 PM   #12
Camper
Banned
no crap... thats why I couldnt pass it up. Guy just picked up a c6 z06 and needed quick cash.
Old 06-03-2013, 08:04 PM   #13
Camper
Banned
lol thats exactly what I have ordered already.
Old 06-03-2013, 08:06 PM   #14
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Bad ass ride. Good luck with it
Enjoy
Mchlgrrsn is offline   Reply With Quote
