SDTW Custom Wheels & Tires
Old 06-03-2013, 07:38 PM   #1
forklord
forklord's Avatar
Drives: 2010 2SS
intake for my e force?
best/cheapest place to get one? looks like only options are roto fab or edelbrock and the edelbrock one is 100$ cheaper. anyone have any experience? thanks
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 06-03-2013, 08:10 PM   #2
epstein
Drives: SS/RS
Send a message via AIM to epstein
Roto fab..... From janetty with tune ... Nuff said
epstein is offline   Reply With Quote
Old 06-03-2013, 08:12 PM   #3
epstein
Drives: SS/RS
Old 06-03-2013, 08:52 PM   #4
forklord
forklord's Avatar
Drives: 2010 2SS
hurry up and post your numbers and vids!!
Old 06-04-2013, 09:02 AM   #5
Alvin@PCMofNC
Drives: 2010 IOM RSS
I'd use a Roto Fab. We have and they pick up a easy 25-35 rwhp. Let us know if you need one or a tune. A tune really wakes up the edelbrock supercharged cars. The canned tune they send out is so soft in timing down low they give up tons of torque.
Alvin@PCMofNC is offline   Reply With Quote
Old 06-04-2013, 11:22 AM   #6
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2012 Silverado LTZ
I have and like the Roto-Fab.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome Torq-Thrust wheels. 546/rwhp & 522/rwtq Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 06-04-2013, 11:30 AM   #7
NicKey
Drives: Nickey Super Camaro
NicKey Stage III 427 E-Force with Roto Fab
We use RotoFab on all the upgraded E-Force applications. Several with 850hp.
NicKey is offline   Reply With Quote
Old 06-04-2013, 12:02 PM   #8
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
25-35 to the rear wheel horsepower? or crank HP? Im looking for a cai but I have not seen those type of numbers to the wheel/ That's pretty impressive.
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
Old 06-04-2013, 03:54 PM   #9
Alvin@PCMofNC
RWHP. Supercharged cars pick up HUGE with a proper intake. Had race cars pick up over 100 rwhp with a good intake over bad one.
Old 06-04-2013, 05:33 PM   #10
forklord
forklord's Avatar
Drives: 2010 2SS
yeah that rotofab looks nice. looks like itll make enough room for my monster RX catch can. nowher else to put it at all. but damned metal tubing. heat soak. why wouldnt they make it out of something else?
Old 06-04-2013, 05:35 PM   #11
forklord
forklord's Avatar
Drives: 2010 2SS
nickey i dont see your heater core lines. just reinstalled mine after cam swap and the damn things rub on the fuel line and the rearmost sparkplug wire. i just cant get them to move and stay put. what the hell am i doing wrong? lol
Old 06-04-2013, 05:37 PM   #12
forklord
forklord's Avatar
Drives: 2010 2SS
sorry for another post but whos got best prices on roto fab?
Old 06-04-2013, 06:16 PM   #13
Rockey33
Rockey33's Avatar
Drives: 2012 IOM Camaro SS
I have an Rotofab with my E-Force and happy with the results.
Rockey33 is offline   Reply With Quote
Old 06-04-2013, 08:38 PM   #14
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '112SS/RS'12CruzECO'11CruzeLTZ,Mini
A few of us on here went the modified CAI Inc route and yes it was a bit surprising how much you pick up with a decent Cold Airbox on FI Apps.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast LS7 Headed 416
SSBUSDRVR is offline   Reply With Quote
