JDP Motorsports
Old 06-04-2013, 09:12 PM   #15
itguy
Drives: CTS-V Wagon
I attached a pic showing my WOT shift points and a log of my very first 1/4 mile run which I managed a 12.1. My car shifted at commanded MPH and not RPM.
Since this was my first time running, I have since tweaked my tune for track use only as traction isn't as good on the street. If I increase my commanded shift points on the street I bounce the limiter when I lose traction.
itguy is offline   Reply With Quote
Old 06-04-2013, 09:13 PM   #16
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Originally Posted by itguy View Post
That table does nothing for your shift points. These tranny's shift by MPH not RPM. Yes, I know this can be confusing but it's true...you can set it to shift at 10000 RPM but if your WOT 1-2 shift is set at 30 MPH that's when it will shift.
IMO, you have to spend some time fine-tuning the shift points on the 6l80e as you also have to consider your converter and even your tire due to traction issues...you have to lead into the shift. With my setup, my 1-2 is at 29 MPH because I know my RPM's climb close to 6900 (HPTuner logging) during the shift. I also utilize torque management - some shops turn it off.
That was probably more than you wanted to read but it is what it is
Experts correct me if I'm wrong as I'm speaking from my personal experience.
Thanks. That sounds kind of confusing, but it sort of makes sense. Last night I was trying to watch when it shifting while barreling down an on-ramp, and it was somewhere over 6000, but it didn't seem like it went all the way to 6500.
Well after reading a little more about it and talking with Livernois, I think I'm just going to leave well enough alone. I initially chose them because of all the good things people said on here. They seem to have a good reputation, so I will trust their judgement. According to them, they have tuned over 2500 cars with DOD/AFM (not just L99's) and have never had a customer with lifter failure due to RPMs. **knock on wood**
Also, since it was tuned on the dyno (as opposed to mail order) I'm assuming they had all the data they needed to set the proper shifts based on MPH.
E.T. is offline   Reply With Quote
Old 06-04-2013, 09:22 PM   #17
white ZL1
Drives: none
Could just be that you're already right at the MPH flag?
I intentionally left my MPH flag's low and figured I'd start creeping up on the shift point that I wanted. And my RPM flags were set right at 6400.....and the shift happened at 6400. As I started upping the MPH, the shifts were still happening at 6400.
Either way, a few others have had the same experience I have.....and others (like you) haven't.
white ZL1 is offline   Reply With Quote
Old 06-04-2013, 09:26 PM   #18
itguy
Drives: CTS-V Wagon
Yep, I wish mine was as easy as commanding the RPM...boy that would have saved me some stress..haha
Old 06-04-2013, 09:51 PM   #19
Supercharged SS
Drives: 2010 Camaro
I'm no expert, but certain T42's definitely don't shift JUST based on MPH. Mine is one of them. 1-2 is almost purely based on mph, but my 2-3 and 3-4 are shifting based on RPM.
This is 1000% correct. This uses both mph and rpm to determine the shift point. There is no way to dictate which one it uses. I know from experience a while back. It took many passes to get the wot shifting perfect. I would bet that 99% of the l99's are shifting all over the place. It takes a lot of effort to get the shift point exactly where you want it.
Old 06-04-2013, 10:29 PM   #20
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
There are Multiple TCM operating systems and they all have they're own Quirks.
Some you can just set the RPM and it will nail it,
some you can just do MPH
some require Both to be dead on or it will favor one or the other.
Any Tire spin and everything goes out the window.
Ted
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 06-04-2013, 10:38 PM   #21
Supercharged SS
Drives: 2010 Camaro
Ted
Isn't it past your bed time?
Old 06-05-2013, 07:13 PM   #22
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Must be working overtime.
Or he's now working late at night because you bug him all the time during the day.
Motion427 is offline   Reply With Quote
Old 06-21-2013, 03:07 PM   #23
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Poked around, okay to piggy back on this thread?
So if I am tuning my own shift points for an L99 with HP Tuners, and let's say I was going for a 6200 shift point on 2-3. Let's say I hit my targeted goal last time with '58' mph and '6000' RPMS in the appropriate tables. So to try to and hit 6200, should I go up 1 or 2 MPH? And should I also command 6200 for RPMs?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 06-21-2013, 04:21 PM   #24
E.T.
E.T.'s Avatar
I can't answer your question, but I don't mind the piggy backing
Old 06-21-2013, 05:14 PM   #25
Motion427
Command the RPM to 6200rpm
Old 06-21-2013, 05:49 PM   #26
white ZL1
Drives: none
Yup. And see what happens. If you don't get your 6200shift, then your car might use mph AND rpm on the 2-3 and 3-4.
I will tell you that you might want to keep bumping your mph up even if you get the shift at the correct rpm. To me, it looks like the TCM is still using the mph to start the pressure adapts for the oncoming and offgoing clutches.
If you log Trans Slip and each of the PCS pressures, you'll see what I mean.
Old 06-21-2013, 06:09 PM   #27
Pro Stock John
Writer
So Dan you would not increase the RPM and MPH both right off the bat?
Also anyone know how to calculate what rpm I'd be with stock tires when I'm going 60mph, and also what gear I'd be in at at 100mph (I'm thinking 4th on this right).
PROJECT HEAVY CHEVY
Old 06-21-2013, 09:58 PM   #28
Motion427
Do you mean at WOT John or just cruising?
