Solo Performance
Old 06-04-2013, 12:29 AM   #1
1sick7
Drives: 2012 camaro convertible ss
turbonetics help , oil drain below baffle ?
is the drain return line suppose to be below or above the oil pan baffle.??
1sick7 is offline   Reply With Quote
Old 06-04-2013, 03:06 AM   #2
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
I would imagine below the baffle but just barely. I have no experience with this kit though.
K32 Camaro is offline   Reply With Quote
Old 06-04-2013, 07:10 AM   #3
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Make sure it is above the oil level in the pan and a little extra above to be safe.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 06-04-2013, 04:08 PM   #4
SSKyle
Drives: 2011 SS/RS
Above would be better, but as long as the fitting is out of oil so that there is no restriction on the returning oil you should be ok.
Drilling the hole exactly 3in from bottom of oil pan like it says in instructions will put you right at the bottom of baffle. At least it did on my car.
SSKyle is offline   Reply With Quote
Old 06-04-2013, 07:53 PM   #5
jordan 572
jordan 572's Avatar
Drives: none
Leaks have been fixed since the picture, praying they stay dry.
jordan 572 is offline   Reply With Quote
Old 06-06-2013, 06:04 PM   #6
TurboneticsRA
Drives: turbo
You should be fine with the recommended distance specified on the installation manual. I attached a PDF copy of the installation manual for reference, page 11.
If you have any questions feel free to email me direct at rawakim@turboneticsinc.com
TurboneticsRA is offline   Reply With Quote
