Old 06-04-2013, 06:36 AM   #1
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
How much power/ factory block/forged internals
How much power will the factory block hold with forged internals?
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 06-04-2013, 06:50 AM   #2
ADM PERFORMANCE
Drives: 2016 CAMARO SS
We stop at 1000hp.
ADM PERFORMANCE is offline   Reply With Quote
Old 06-04-2013, 09:03 AM   #3
old motorhead
Drives: Maggie blown LS3 vette
Originally Posted by ADM PERFORMANCE View Post
We stop at 1000hp.
Andy, do you use a forged crank at the level? If so, how far do you push the stock crank?
old motorhead is offline   Reply With Quote
Old 06-04-2013, 09:25 AM   #4
blake-b
blake-b's Avatar
Drives: Black 2010
1000 crank or rwhp?
Old 06-04-2013, 09:28 AM   #5
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I didn't want to go over 700 with 4 bolt heads, that's the real weak point on the LS3.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 06-04-2013, 10:21 AM   #6
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
Do you mean 4 bolt main?
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 06-04-2013, 10:31 AM   #7
blake-b
blake-b's Avatar
Drives: Black 2010
No he means the heads. Stock ls3/l99 blocks and heads only have provisions for 4 bolts per cylinder, limiting their resistance to cylinder pressure.
I am using 6 bolt heads on my 4 bolt block because they have a thicker deck to resist lifting. I also bought them because I will be using a 6 bolt block on the next iteration.
I am over 1000 crank hp with my stock crank with forged rods and forged pistons as well. It is a centri setup and they are typically easier on parts.
Old 06-04-2013, 10:42 AM   #8
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
It's pretty amazing how much power the stock LS blocks are holding. The ARH/FARK Camaro made 1300 with a forged 416 and the stock LS3 block, but that really pushing it.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 06-04-2013, 11:32 AM   #9
Unreal
Drives: 2006 Z06
Plenty of people make 1100+ on 4 bolt heads. Good gaskets, L19 1/2" studs work wonders. Plus a lot of shops like to keep 4 bolt heads as a fuse. If it pings it will take out a headgasket before a piston if you are lucky.
Nick
Corvette Z06 -1200ish rwhp
Old 06-04-2013, 11:47 AM   #10
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
You need at least 1000 RWHP for internet racing.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 06-04-2013, 11:53 AM   #11
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
We have 6 bolt mains
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 06-04-2013, 02:05 PM   #12
old motorhead
Is there a factor to convert internet hp to rear wheel, flywheel, or real world/no sh!t type power? Can you calibrate an internet dyno to reveal those other, less important numbers
Old 06-04-2013, 02:46 PM   #13
james347
Drives: 2006 Crownline
james347 is offline   Reply With Quote
Old 06-04-2013, 04:04 PM   #14
Alvin@PCMofNC
Drives: 2010 IOM RSS
Seems like boost is the issue with lifting the heads.. The magic number is between 22-23 pounds before it starts trying to push water.
Alvin@PCMofNC is offline   Reply With Quote
