HURST
Old 06-05-2013, 02:07 AM   #1
Rjizzle10
Drives: '13 Hot Wheels SS
CAI vs Fastlane vs ADM Cold Air Intakes
Currently what is the best one as far as acceleration, sound, no lag, no maintenance?
From tests it seems like Fastlane was on top but people say it looks like its made out of crap. For $500 dollars I don't want a 'home depot thrown together pipe'
Another concern about the Fastlane CAI that I had was how well can you drive in the rain and through puddles with it since it is located not far from the ground?
Rjizzle10 is offline   Reply With Quote
Old 06-05-2013, 02:28 AM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
Well If you have concerns what so ever about Fastlane then cross them out. Reason why I ended up with the ADM race intake was due to the fact that the MAF sensor is boxed in with the filter for cooler temps. It also has the scoop and been driving it in the rain all last week and its fine. Just sharing my opinion.
62nalide is offline   Reply With Quote
Old 06-05-2013, 03:19 AM   #3
BlaqWhole
BlaqWhole's Avatar
Drives: 2017 Camaro ZL1 A10
I personally don't like the fenderwell style intakes because of the potential of driving through deep puddles. I love my Vararam intake, but outside of that I would get an underhood style intake that is sealed off and has a scoop.
2017 Camaro ZL-1 A10 - Roto-Fab cai - Katech ported TB - MBRP Race catback - VTC!!
2017 Challenger Hellcat M6 - Legmaker CAI - MM ported TB - Sprint Booster!!
Saving the world...1 hp at a time!!
BlaqWhole is offline   Reply With Quote
Old 06-05-2013, 05:16 AM   #4
dynosteve
Dyno Tuner & Calibrator
dynosteve's Avatar
Drives: 2010 SS Camaro Turbo
Vararam is probably the best performing system on the market and is USA made
RDP Store www.rdpstore.com
Shop 440 358 5500
Cell 440 251 8571
Kooks ARH Stainless Power HP Tuners Ngauge Diablosport SCT Edelbrock Whipple Magnuson Rotofab CAI Fore DSS Mishimoto Borla Magnaflow Corsa Trutrac EBC
dynosteve is offline   Reply With Quote
Old 06-05-2013, 09:08 AM   #5
ssmike
Missing Big Red
ssmike's Avatar
Drives: '13 Equinox CRT
Old 06-05-2013, 09:14 AM   #6
Rjizzle10
Vararam has a weird style to it doesn't it? Any pics of it under the hood?
Old 06-05-2013, 09:17 AM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Search, there are Many bud.
Old 06-05-2013, 09:33 AM   #8
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Yep, lean the radiator in and install. They're great intakes but I'm not a fan of the "radiator lean" look.
2011 L99 W/ Kooks Long Tubes, Ported TB, Roto-Fab CAI, MightyMouse can, Stainless Works 3" ZL-1 Catback, Overdriven Maggie @10 Pounds boost putting down 511/535 on a conservative tune.
Nutro is offline   Reply With Quote
Old 06-05-2013, 09:42 AM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Not a big fan of leaning the radiator either, but it does work well. . Don't get one with a metal tube because of heat soak. I personally like roto fab but most of them perform about the same. It's a 12hp part, it's not going to make or break your car. Enjoy
Mchlgrrsn is offline   Reply With Quote
Old 06-05-2013, 10:00 AM   #10
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I gave my report of this very intake just the other day. Its on this very forum page titled pipeline.
Old 06-05-2013, 11:51 AM   #11
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
ADM all the way if your on the fence! Vararam does make good power but I don't care for the look at all. ADM intake IMO has the best balance of looks, quality of materials and design, and performance! And add the scoop and she's a bad b!tch! Plus Andy at ADM is excellent in customer service!
Camarojt is offline   Reply With Quote
Old 06-05-2013, 11:57 AM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If your car is a 12 or newer, that would eliminate the VR.
The rest are EASILY found with a simple search. Just type the name of the intake you're wanting information about in the "search this form" box, found in each section.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-05-2013, 12:12 PM   #13
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
I have the Vararam and I'm very happy with it. I think it looks good and performs just fine. The installation is a little off but I never had an issue with it in 9 months that I've had it. I'm taking it off soon to replace with a CAI and that's just because I'm installing a Magnacharger and Vararam won't work. The tilting back of radiator is really easy and isn't noticible once installed. Not saying its better them others just that I like it and like the idea it gets air from outside engine.
11TexaSS is offline   Reply With Quote
Old 06-05-2013, 01:35 PM   #14
BlaqWhole
BlaqWhole's Avatar
It's a unique style. Yea you have to lean the radiator back to install it. But you probably won't notice it once the intake is installed. I was a little skeptical of it at first but it is a simple install. And leaning the radiator has no affect on cooling.
