Emblempros
Old 06-05-2013, 12:43 PM   #15
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
I picked up everything I needed except the drive shaft for $800. Don't remember how much the install was. That was with 3.45 gears, so you would still need to figure in the price of the 3.91 gears and installation.
I think you should really do some research beyond price. 3.91 is a lot of gear for the V6 A6. You will have to shift to third just to get up to 70 MPH and you will be running about 2200 RPMs at 70 in sixth gear.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 06-05-2013, 12:51 PM   #16
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
Meaning what I'm not too familiar with the gear systems.
AmericanMuscleCars is offline   Reply With Quote
Old 06-05-2013, 12:53 PM   #17
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Gears are an awesome upgrade and made a big difference on my SS. Unfortunately, it sounds like an awful lot of work to do shorter than 3.55 on the V6. For the SS, the common recommendation is 3.70 for the auto, and 3.91 for the manual. So maybe in your case, 3.70's would work a little better. As for the install, that's something I wouldn't mess with myself. They have to be set up just right, or you will have problems.
E.T. is offline   Reply With Quote
Old 06-05-2013, 12:54 PM   #18
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
exactly what he is saying....getting gears if i remember correctly actually lowers your top speed. Youll also be using more gas at highway speeds due to being at higher rpms
FaytalsCamaro is offline   Reply With Quote
Old 06-05-2013, 12:55 PM   #19
FaytalsCamaro
and to be completely honest i dont think 3.91 gears is worth it on a auto v6. considering the swaps youll have to make. On top of everything youll need a tune
Old 06-05-2013, 12:57 PM   #20
AmericanMuscleCars
Gotcha, I guess I'll just stick with getting my catch can then lol.
Old 06-05-2013, 01:00 PM   #21
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Had mine done a couple weeks back. I went with 3.73's though. IF u are going to pay someone to do it figure $2k-$2300 depending options for everything. I went with BMR bushings and JRE clutches in the LSD unit.
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 06-05-2013, 01:12 PM   #22
GretchenGotGrowl
Here is the MPH for each gear at 3800 RPM for the stock 3.27 gear on a A6 V6.
1st: 43
2nd: 76
3rd: 113
4th: 151
5th: 207
6th: 262
At 70 MPH in 6th you are running ~1800 RPM
Now with the 3.91 gear
1st: 36
2nd: 63
3rd: 95
4th: 127
5th: 173
6th: 219
At 70 MPH in 6th you are running ~2200 RPM
You gas mileage will be worse. Your first gear will be just about worthless, and you will probably have to tune it to shift sooner from 1st to 2nd to keep from hitting the rev limiter. That will put you lower in the RPMs when you hit second, below the sweet part of the power band. First fear might be fun with these gears, but it will probably make your car slower, not faster. I would not go above 3.55 on a A6 V6 unless you have something that really bumps up the low-end torque, or you got a custom torque converter to keep you in the power band. In my opinion, it isn't worth the effort until you have built the car to the power you want and you have the right torque converter. When all that's done get the right gear to match your power and output and get the greatest acceleration you can.
Old 06-05-2013, 01:42 PM   #23
SC2150
We do the 3.55's in the open diff v6 A6 cars, or complete conversions to add the LSD diff and all components as well. Usually have it all in stock.
Old 06-05-2013, 02:05 PM   #24
AmericanMuscleCars
Price?
Old 06-05-2013, 02:06 PM   #25
AmericanMuscleCars
1st: 43
2nd: 76
3rd: 113
4th: 151
5th: 207
6th: 262
1st: 36
2nd: 63
3rd: 95
4th: 127
5th: 173
6th: 219
Thanks! This is awesome info, I appreciate it! Cleared it up for me!
Old 06-05-2013, 07:46 PM   #26
Netraa
Drives: 2014 2ss/rs
1st: 43
2nd: 76
3rd: 113
4th: 151
5th: 207
6th: 262
1st: 36
2nd: 63
3rd: 95
4th: 127
5th: 173
6th: 219
<snip>.
Well, that's one way to cut down on the drone....
Netraa is offline   Reply With Quote
Old 06-05-2013, 08:16 PM   #27
GretchenGotGrowl
Never thought of that.
Old 06-07-2013, 02:07 PM   #28
jbrantner24
Drives: 2013 Camaro LS M6
It will only lower your top speed if you plan on going over 200mph. Never happen in a 6. it should actually raise what you can achieve by adding more torque to the wheels to fight the drag that will limit you without a governor.
K&N intake, Resonated X-pipe w/muffler delete, Trifecta Tune, rashes up sport muscle tachs.
jbrantner24 is offline   Reply With Quote
