Jason 98 TA
Old 06-05-2013, 11:45 AM   #1
fastfreddie
FreakyFast!
fastfreddie's Avatar
Drives: 2010 2SS/RS S/C NicKey #55
Mild Cam vs BIG Cam?
I've been reading and studying about CAM's and there seems to be alot of talk about Mild Cam's for DD's and then BIG Cam's for more HP. I've done some searching but haven't found an answer to what I'm looking for.
I'm assuming a Mild Cam is somewhere around 231/236. What is considered a BIG Cam? Also, what are the pros and cons to a BIG Cam?
Thanks for the help!
2010 2SS/RS #55 NicKey Stage 2S Super-Camaro custom painted by Pete (Mr. Showstopper)
Build Thread: http://www.camaro5.com/forums/showthread.php?t=250743
fastfreddie is offline   Reply With Quote
Old 06-05-2013, 11:48 AM   #2
steveo9043
steveo9043's Avatar
Drives: 2012 45th AE 2SS Coupe
If i'm not mistaking a big cam will require a higher stall which will take away the street ability. I don't think that is the only pro/con. I'm subscribing to see tho as I am looking into a cam soon as well.
Did me beating you on the dyno make you want to do this? lol jk
steveo9043 is offline   Reply With Quote
Old 06-05-2013, 11:55 AM   #3
JEFF75645
Drives: his wife crazy buying mods
I have a 223/236 59X-60X. I'm not sure where the line is drawn for mild-wild. There was a thread a while back debating different size cams and what category that fall into. As far as stall I think the dyno graph kinda tells you what stall you will need.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 06-05-2013, 11:56 AM   #4
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
The TSP 231/236 isn't a mild cam if that's the one your talking about. A mild cam is just a cam that has less duration and less lift. Less duration means that it will idle better and drive better at low RPM. Less lift will be easier on your valvetrain. What you should buy all depends on what you're hoping to get out of the cam. The 231/236, G6X3, Night Fury, etc.. are all big cams.
I'm not the one to be answering from an auto tranny point of view as I have an LS3.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-05-2013, 11:58 AM   #5
MrBowTi3
MrBowTi3's Avatar
Drives: 2013 1SS Victory Red Camaro
Check this out it will be informative at the least
http://www.camaro5.com/forums/showthread.php?t=290089
Sent from my SPH-D710 using Tapatalk 4 Beta
MrBowTi3 is offline   Reply With Quote
Old 06-05-2013, 11:58 AM   #6
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Lumpy idle is caused by low vacuum. Basically the engine want's to stall. This leads to drivability issues when putting around town.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 06-05-2013, 12:08 PM   #7
DrkPhx
DrkPhx's Avatar
Lumpy idle is caused by overlap; low vaccum is a by product of overlap. I would define the cams listed in this thread (so far) as mild. Anything above 20 degrees of overlap at .50 is considered wilder in my book. Approaching 30 degrees is WILD. The cam in my last car (LS 402 stroker) had 26 degrees of overlap. It took a lot of tuning; but it idled and drove good considering the setup (11.7 cr, 5000 stall, 3.73 gears).
DrkPhx is online now   Reply With Quote
Old 06-05-2013, 12:16 PM   #8
KCS
KCS's Avatar
Drives: 2000 Pontiac Trans Am
There is no black and white answer, it's all relative. Displacement, cylinder heads, operating range, etc all play a role in what cam is needed, and what would be "big" or "small".
Now if you were to narrow it down to say a 376ci LS with LS3 heads, then you can begin define what cams are too big or too small.
Generally speaking, a cam will "rock" the power curve with peak torque being a fulcrum if you will. More duration will hurt lower RPM power, while picking up higher RPM power.
KCS is offline   Reply With Quote
Old 06-05-2013, 12:21 PM   #9
fastfreddie
FreakyFast!
Absolutely....you really pissed me off!
Old 06-05-2013, 12:23 PM   #10
thahemp
Geek
thahemp's Avatar
That's a good way to describe it.
x = ~x
Old 06-05-2013, 12:26 PM   #11
fastfreddie
FreakyFast!
Thanks guys for the replies. Great reading APEX Chase's post. I hadn't run across that, not sure why. I think I'll eventually get a handle on this CAM thing. Guess I was misinterpreting what defines a Mild Cam and BIG Cam.
Now I just need to win the lottery!
Old 06-05-2013, 01:31 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Pros and cons are, when you get the mild cam after a few months or sooner your gonna wish you had the bigger one. Mark my words. Lol
Old 06-05-2013, 02:06 PM   #13
fastfreddie
FreakyFast!
Alex told me to never listen to your advice.
J/K
Old 06-05-2013, 02:16 PM   #14
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
Getting my cam and conversion done next week...
MARINE1991 is offline   Reply With Quote
