BORLA
Old 06-05-2013, 02:12 PM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Color matched intake manifold
Decided to try something different, color matched intake for my LFX also did valve covers. Complete pictures in my photo album.
etmx183 is offline   Reply With Quote
Old 06-05-2013, 02:14 PM   #2
etmx183
etmx183's Avatar
Painted valve covers to match.
Old 06-05-2013, 02:18 PM   #3
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
That looks great ! I wonder how I can paint mine singer green.
Can any one chime in in that ?
Old 06-05-2013, 02:22 PM   #4
etmx183
etmx183's Avatar
I used Krylon Fusion paint, painted it white first two coats. Let it dry for 48 hours, than 3 coats of their bright yellow. We will see how it holds up over time. Thanks for the feedback, I know this is something different was not sure how it would be received.
Old 06-05-2013, 02:36 PM   #5
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
When u coming to Florida to paint mine? Bring some blue crabs with u, i miss them!
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is online now   Reply With Quote
Old 06-05-2013, 02:46 PM   #6
LIM3
LIM3's Avatar
Drives: SGM
Let's schedule something haha.
He did a great job on painting.
Btw, you really have upgraded your car with some performance. Do you plan to go supercharge ?
Old 06-05-2013, 03:34 PM   #7
IneedAZ
IneedAZ's Avatar
Not the 2012, i will be supercharging the 67 and pulling off the nitrous. I have been toying with the idea off putting a 75shot of nitrous on the 2012 though. I was hoping to hit the track soon, but now its rainy season so i am not sure when i will get there plus its hot and humid for the next several months.
Old 06-05-2013, 03:39 PM   #8
LIM3
LIM3's Avatar
Drives: SGM
Man I would love to own a 1st gen.
Let alone modding it to be a 1/4 beast.
A shot of nitrous will really make the difference in your 2012.
Your suspension and other supporting modifications will compliment it nicely.
Old 06-05-2013, 11:41 PM   #9
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Are you planning on putting all the sound deadening pads back on the valve covers or running without them?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 06-06-2013, 10:27 AM   #10
etmx183
etmx183's Avatar
No sound pads going back on. look at my mods I'm not worried about some extra noise.
Old 06-06-2013, 11:10 AM   #11
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Yeah, I kind of laughed a little at that question myself. I like taking sound deadening material out.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 06-06-2013, 11:22 AM   #12
etmx183
etmx183's Avatar
I have driven it since replacing the intake and VCs and I can not hear any difference with the sound guards removed. I did leave the bottom of the intake and lower intake plenum in white to reflect heat ( hopefully ).
Old 06-06-2013, 11:47 AM   #13
IneedAZ
IneedAZ's Avatar
what shot of NOS on that 12.7 run?
Old 06-06-2013, 04:08 PM   #14
etmx183
etmx183's Avatar
100HP pills, bottle pressure @950 PSI. Front stock tires @65PSI, stock rear tires @28 PSI, held at 1,000 RPMs on the brake. Temp 61, DA= 225'. When the RPMs hit 3k I went on the bottle. I use finger activated switch so if I'm ahead I only use what I need to stay ahead and can stay at WOT the whole time on all motor.
