Caryle Racing
Old 06-05-2013, 03:44 PM   #1
M.D.P84
M.D.P84's Avatar
Drives: Camaro V8
Question add 3.91 gears in my camaro L99
hello friends, well I wanted to know what the advantages of having 3.91 gears. good in terms of launching from 0 to 60mph, and that changes in top speed? gains some wrhp?? can help me to clarify these doubts??
M.D.P84 is offline   Reply With Quote
Old 06-05-2013, 03:53 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Torque...or the feel of....Yes. HP....none.
You might have more problems launching because it will probably smoke the tires way more. Consider 3.70 gears.
Build Journal
Old 06-05-2013, 03:56 PM   #3
Dznts
Anabolic Connoisseur
Dznts's Avatar
+1 for 3.70 gears
Old 06-05-2013, 04:03 PM   #4
M.D.P84
M.D.P84's Avatar
Drives: Camaro V8
3.70 would be good?? The Camaro 1LE has 3.91 gears, right?? the release will be harmed with 3.91 gears? I'm thinking of doing this mod, to improve launch 0A 60mph or 1/4 mile. thanks for the explanation
Old 06-05-2013, 04:24 PM   #5
the_fast_one
the_fast_one's Avatar
Drives: 2012 IOM 2SS, 05 SOM Colorado
The 1le has 3.91 but it has different gears in the tranny to off set it. Most auto are going to 3.70 do to the gears inside the auto tranny.
the_fast_one is offline   Reply With Quote
Old 06-05-2013, 04:31 PM   #6
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
What are the stock L99 gears - 3.27 or 3.45? What are the gains over them by going to 3.70? Does changing gearing require a tune?
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 06-05-2013, 04:44 PM   #7
Lgndryhr
Camaro Die-Hard
Lgndryhr's Avatar
Drives: 2010 2SS/RS L99 IOM
Auto should upgrade to 3.70
Manual should upgrade to 3.91
Phoenix (click for build thread)
13.282 @ 107.70 (100% Stock)
12.481 @ 110.92 (Current mods as of 5/6/16)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
Lgndryhr is offline   Reply With Quote
Old 06-05-2013, 06:09 PM   #8
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Stock L99 gears would be 3.27
Tune would be required for the speedometer to be accurate aswell for the tranny to shift correctly.
Motion427 is offline   Reply With Quote
Old 06-05-2013, 06:10 PM   #9
M.D.P84
M.D.P84's Avatar
Drives: Camaro V8
I found to buy 3.73 and 3.70, which would be better?? the site has phastek 3.91 to automatic, http://www.phastekperformance.com/20...-gears-391.htm!! what suggestion do you have?? what changes in 0/60mph with 3.73 or 3.91 gears?? top speed decreases or increases?? can affect it?? or could benefit the top speed?? before this mod, I need to have this information, thank you for the comments guys.
Old 06-05-2013, 09:01 PM   #10
Baltimorejohn1
Baltimorejohn1's Avatar
Drives: Camaro 2SS
OP one way to checkout your question is to see what people are running using the setup you are talking about...... I hope this helps out....
3.70
4.10
4.10
Also check the Fast List and see what is working
Baltimorejohn1 is offline   Reply With Quote
Old 06-05-2013, 09:48 PM   #11
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Only do the 3.91's if you are cammed or have a triple disk aftermarket converter. Otherwise do like others said and get the 3.70's. I dont consider wheel spin from 3.91 gears to be the biggest issue as you could always use bigger and stickier tires. Its the fact that it forces a shift into 5th too soon if you dont have a cam with a higher redline or triple disk converter that can be locked up at WOT.
Old 06-06-2013, 04:45 AM   #12
M.D.P84
M.D.P84's Avatar
Drives: Camaro V8
3.70
4.10
4.10
thank you very much, loved the videos
Old 06-06-2013, 04:48 AM   #13
M.D.P84
M.D.P84's Avatar
Drives: Camaro V8
thank you, with 3.91 can hurt top speed ... better off for 3.70!!
Old 06-06-2013, 05:21 AM   #14
Motion427
Shouldn't hurt top speed with 3.91's. It would take alot of HP to reach redline in 6th gear for sure.
