ADM PERFORMANCE
Old 06-05-2013, 05:14 PM   #1
Rob Grant
Custom User Title
Rob Grant's Avatar
Drives: 2012 Camaro 45th Anniversary
What am I doing wrong ???
2012 Auto,vert,SLP supercharger stage 3 650hp,370 rear gears,weld rims and Hoosier rear slicks. I'm not happy with numbers
Rob Grant is offline   Reply With Quote
Old 06-05-2013, 05:20 PM   #2
SC2150
1/8th mile......will need to know a lot more about your runs. Any tire spin? Weight transfer working well? What tire pressure? Is the front sway bar disconnected? Skinnies on front to match the slicks? (must be biased ply or sashy down the track could get you loose).
Have adjustable coilovers on the back set to app 50/50 to start?
Old 06-05-2013, 05:34 PM   #3
Rob Grant
Custom User Title
Rob Grant's Avatar
Any tire spin? did not feel any
Weight transfer working well? no idea
What tire pressure? 20lbs
Is the front sway bar disconnected? no
Skinnies on front to match the slicks? no
Have adjustable coilovers on the back set to app 50/50 to start? no
Old 06-05-2013, 06:00 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
Stock converter?
Here is an example of another car, a Convertible, small cam, stock converter, full exhaust on 22's:
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Pro Stock John is online now   Reply With Quote
Old 06-05-2013, 06:28 PM   #5
Rob Grant
Custom User Title
Rob Grant's Avatar
It is a stock converter. I thought with a supercharger (650hp),I would do better than I did.
Old 06-05-2013, 06:55 PM   #6
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Mph looks very low for that kind of power.
Rhino79 is offline   Reply With Quote
Old 06-05-2013, 07:28 PM   #7
Rob Grant
Custom User Title
Rob Grant's Avatar
it does, not sure what is wrong
Old 06-05-2013, 08:05 PM   #8
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
Originally Posted by Pro Stock John View Post
Stock converter?
That is an awesome time for a vert on 22's!
Irnwkrkev is offline   Reply With Quote
Old 06-05-2013, 09:20 PM   #9
Rdunn
9.2@147mph
Rdunn's Avatar
this 650 flywheel or rwhp?
also how much did you let the car cool down? if there is any heat in the car, it will start pullin timing as the iat's climb.
my car with 650whp cold will run 7.0@100mph
now same set up hot will run 7.4.@95mph
heat plays a HUGE factor in how these cars run. i drive my car 45 mins to the track. so as soon as i get there i pop the hood, throw a bag of ice on the whipple and wait atleast an hour before i make a pass. to where the car is completely cooled off. then by the time i get thru the staging lanes it at the perfect temp for racing.
Procharger F1X, 4L80E, E85, CBI Street Cars, DSX Tuning
Rdunn is offline   Reply With Quote
Old 06-05-2013, 09:36 PM   #10
Supercharged SS
Drives: 2010 Camaro
You're launching the car wrong or like these guys said you are spinning. 1.60 is attainable with the stock converter. Did you log the pass with mph as a pid?
Old 06-06-2013, 12:08 PM   #11
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Its got to be in the launch. Am below 600 RWHP with 18" D/R stock fronts 1.60s is bad for my 60' and 1/8 mile 100 plus MPH
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 06-06-2013, 12:50 PM   #12
Rob Grant
Custom User Title
Rob Grant's Avatar
650 fly wheel hp and the weather was hot, around 32c and I had let the car sit for an hour between each run. When I put the line lock on and then did my burnout, the computer screen say service stabilizer and seems to shut off the traction control and nannys. Even if I shut off traction control and stabilizer before I burnout, the screen says the same thing. I thought maybe the computer was shutting down on the power for some reason. What is the best air pressure for my 18' slicks ( hoosier) ?
Thanks for all your info and I want to be able to give the car a good run.
Old 06-06-2013, 01:19 PM   #13
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Your stability control thinks it's malfunctioning due to the line lock. It's sensing the rear wheels spinning, and the front wheels stopped without the brake pedal being applied.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 06-06-2013, 01:28 PM   #14
Mr. Nasty
Mr. Nasty's Avatar
Not sure about the hoosier slicks. I have played with the air as low as 15psi in the 18" M/T DR and found they work best for me with 20psi.
