Cold Air Inductions
Old 06-05-2013, 07:38 PM   #1
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Boost gauge?
Everyone running a boost gauge?? Which is better the avg?
11TexaSS is offline   Reply With Quote
Old 06-05-2013, 10:20 PM   #2
NOT URSS
NOT URSS's Avatar
Drives: 2010 2SS/RS Camaro
Send a message via AIM to NOT URSS
I have been using the AEM boost gauge.. looks good easy install
632RWHP/556RWTQ
NOT URSS is offline   Reply With Quote
Old 06-05-2013, 10:27 PM   #3
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
+1
Matches the dash well
Mchlgrrsn is offline   Reply With Quote
Old 06-05-2013, 10:31 PM   #4
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Day shot
Old 06-06-2013, 01:30 AM   #5
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
ProSports Evo Series, red & blue led matches interior perfectly
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 06-06-2013, 05:02 AM   #6
11TexaSS
11TexaSS's Avatar
All look nice!
Old 06-06-2013, 06:22 AM   #7
NOT URSS
NOT URSS's Avatar
632RWHP/556RWTQ
Old 06-06-2013, 06:30 AM   #8
dynosteve
Dyno Tuner & Calibrator
dynosteve's Avatar
Drives: 2010 SS Camaro Turbo
I prefer to run the aeroforce system which is a gauge that can handle any item that the pcm puts out through the OBD2 port
http://www.rdpstore.com/p-499-aerofo...or-gauges.aspx
RDP Store www.rdpstore.com
Shop 440 358 5500
Cell 440 251 8571
Kooks ARH Stainless Power HP Tuners Ngauge Diablosport SCT Edelbrock Whipple Magnuson Rotofab CAI Fore DSS Mishimoto Borla Magnaflow Corsa Trutrac EBC
dynosteve is online now   Reply With Quote
Old 06-06-2013, 07:38 AM   #9
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Check out dynotunenitrous.com. Nice little square gauge that has boost and AFR split screen, or chose any 2 parameters and colors you want when you order it.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 06-06-2013, 11:44 AM   #10
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
I will also be putting in boost and air/fuel gauges in mine.Mchlgrrsn looking at your average fuel at 10.9 MPG makes me feel a little better about my 11.8 MPG LOL
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 06-06-2013, 01:31 PM   #11
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
I am running the Pro Sport Evo style like Kronx. I like the look and function of the gauges, but have found out that there is no way to get the AFR to data-log. I have had several conversations with Pro Sport and they tell me they are working on a module that will allow data logging but it is not available yet. The analog out-put from the current module is only to connect the wide-band sensor to the car's computer. Not sure what good that would do, but that is what they designed. If you need to data-log I would stay away from these for right now until they get their module up and running.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 06-07-2013, 09:35 AM   #12
11TexaSS
11TexaSS's Avatar
Anyone have any experience with gauges from PLX Devices?
