BORLA
Old 06-08-2013, 11:44 PM   #15
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
Originally Posted by Stingr69 View Post
Not much to add to what has been said before but I put the LS-9 cam with the Edelbrock E-force supercharger and do not regret it at all. Cheapest, easiest and least compromising 25 HP you will ever get.
-Mark.
Originally Posted by white1LE View Post
Installed the cam tonight. Ted Jannetty whipped up a tune for me at short notice, use that until I put the charger on wednesday. Took longer than I originally said,a shade over 3 hours, and that included pinning the crank while I was there, and a little BSing of course. Car runs great thanks to Ted. Glad to hear everyone likes the cam and charger combo, makes me look forward to the end result.
I'm so glad someone posted this thread. I was thinking about doing the same thing this morning, just wasn't sure how to go about it. My ultimate goal is to install an Edle Brock SC but wanted to have a mild cam , like the LS9 cam, installed prior to the SC. I would greatly appreciate it if you guys would post individual videos of your setups, for scientific research. LOL .... thanks!
Sapper12b is offline   Reply With Quote
Old 06-09-2013, 04:41 AM   #16
chevy27
Drives: ls3 camaro ss
just a quick question i have a ls3 2011 camaro how much hp gain i will get from bolt ons and ls9 cam only ?
chevy27 is offline   Reply With Quote
Old 06-09-2013, 05:27 AM   #17
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I could make a video but it would bore you to tears. No change in engine idle or exhaust sound. If you want your cam change to be noticeable, you want a different cam. Personally, I like my car mods to be completely stealthy. Look, sound and cruise like stock but the E-force and LS-9 cam setup makes the engine feel like it is 25% bigger than it was before. It's not going to please everybody but it works for me.
-Mark.
Old 06-09-2013, 06:20 AM   #18
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
With my car you can faintly tell that it has a cam in it. A coworker just asked me a couple of days ago if I had "cams" and said that he knew it wasn't a spark miss.
I have a 700rpm idle though, and if I were to get it turned up a little it would disappear most likely.
You can expect an extra 20hp at peak and it will rev a few hundred rpm higher over standard bolt ons. You will lose a little torque down low but the bolt ons will make up for it over stock torque anyway.
Irnwkrkev is offline   Reply With Quote
Old 06-09-2013, 10:54 AM   #19
Sapper12b
HTCC Member
Sapper12b's Avatar
-Mark.
Stealth/sleeper is what im going for and i dont mind getting bored
Old 06-09-2013, 03:51 PM   #20
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
Actually had 4 hands, me and a buddy. There easy very slight evidence of a different cam in the exhaust note. I'm happy with it anyway. All you need is a cam, LS9 cam sprocket and 3 cam bolts. Very simple swap. Didn't even pull the A/C refrigerant. My car only has 2000 miles on it so no gaskets and seals needed. A few thousand more miles and I would have replaced cover gasket and crank seal. Take that back, replaced coolant pump gaskets, that's always a given in my opinion. Very happy with how the car performs. Can tell in the seat of my pants and to me that's worth $150.
white1LE is offline   Reply With Quote
Old 06-09-2013, 04:05 PM   #21
Sapper12b
HTCC Member
Sapper12b's Avatar
That's great, any other mods like headers or exhaust? I would like to hear the subtle difference , if possible. I wish I had friends like you that could help me swap out a cam in roughly 3 hours. I'm sure your 1LE is is just that much better now. So other than the parts you listed nothing else is required to make it work or fit in the LS3?
Old 06-09-2013, 05:37 PM   #22
white1LE
white1LE's Avatar
Headers and CAI right now. Have npp exhaust. Only other thing required is a tune.
This swap is very easy actually. If it makes you feel better follow the DIY section for cam swap, I checked it out before doing mine since it's the first 5th gen I've done and found a couple helpful tips. No need to raise the car in the air or on stands as long as you can reach the coolant petcock to drain radiator. The whole jod is only a matter of nuts and bolts and a little "attention to detail" when installing the new cam gear and aligning the marks.
Old 06-09-2013, 06:41 PM   #23
Sapper12b
HTCC Member
Sapper12b's Avatar
Thanks ! I'll definitely take a look at that thread. I would like to see some numbers if you ever get your 1LE on the Dyno.
Old 06-09-2013, 07:55 PM   #24
white1LE
white1LE's Avatar
Installing the SLP TVS2300 wednesday night so I won't have any numbers for this combo.
Old 06-09-2013, 08:16 PM   #25
Sapper12b
HTCC Member
Sapper12b's Avatar
I would still like to see the numbers that your 1LE puts out with the SC. My ultimate goal is to have a SC on the Camaro with the LS9 cam, headers, and CAI.
Old 06-09-2013, 10:09 PM   #26
white1LE
white1LE's Avatar
Will do. Excited to find out myself
Old 06-20-2013, 07:29 AM   #27
Sapper12b
HTCC Member
Sapper12b's Avatar
Any updates ?
Old 06-20-2013, 09:55 PM   #28
white1LE
white1LE's Avatar
Sorry I haven't had anything to update. I did receive the charger yesterday. Kris at Jannetty rattled some chains at SLP to get them to send it out, thanks Kris!!! Installing it tomorrow night after work. Read through the directions a couple times and compared to a Kenne Bell I installed a couple years ago on my C5 vette, this will be a cake walk. Kit is nicely done. It says 6 hours, will be happy if I get it done anything under that. Ted already sent me my tune so as long as the install goes ok I'll be driving it home same night.
