BORLA
Old 06-06-2013, 09:44 AM   #1
fab410
@fabSSbuild on IG
fab410's Avatar
Drives: 2012 Twin Turbo Super Sport
ZL1 bumper (how to operate fog & drl)
I have Camaro SS (non rs) with a ZL1 bumper installed. I also have the RS Headlights (halo ring etc). The issue that I am having is how to get my fog lights to operate. Currently if i press the fog light button, the DRL lights come on. I wanted it to work were as if i start my car normally prior to night, the DRL will come on...when i turn my head lights on, the drl's shut off and when i press the fog light button..the fogs come on.
Can someone point me in the right direction
Thanks
AGP Twin Turbo, FAST lsxR manifold, ID850's, Squash Return Style Fuel System, ZL1 Bumper/Side Skirts/Hood/Carbon Insert, Havoc Rear Diffuser, PFADT Coilovers/Sway Bars/Adj. Tie Rods/Solid Subframe Bushings/Trailing Arms, Eboost2, SW Retro Chambered 3" Catback, R1 Concept Drilled/Slotted Rotors, 360 Forged Straight 5's, Matte Metallic Purple Wrap, Anvil Carbon Spoiler, Full AAC Lighting, etc
fab410 is offline   Reply With Quote
Old 06-06-2013, 09:51 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Do you have the ZL1 conversion harness from Gen5 DIY? If not then that's your answer.
Click to view my build thread
Old 06-06-2013, 11:43 AM   #3
usranger80
usranger80's Avatar
Drives: 2011 1LT "Bumblebee"
Was your car a factory RS car or did you add the headlights? I ask because you said you have a fog light button, wasn't sure if you meant a factory one or not, I thought the RS version of our cars didn't come with a fog light button and that it wouldn't work even if you added the switch and Ofer's harness.
usranger80 is offline   Reply With Quote
Old 06-06-2013, 11:51 AM   #4
The Stig
The Stig's Avatar
Says he has a non-RS and upgraded to the RS headlights.
Old 06-06-2013, 01:21 PM   #5
fab410
@fabSSbuild on IG
fab410's Avatar
^ thanks...I have the non RS and upgraded to the RS Headlights.
I also have the ZL1 wireharness from offer but I am still having that problem.
Old 06-14-2013, 12:03 AM   #6
Cmitopgun
Cmitopgun's Avatar
Drives: 2011 Camaro 1LT/RS
I too am having a fog light problem. I picked up a ZL1 harness, part number 22840497. I have a 2011 V6 with RS package. I hooked it all up and all lights work as designed with the exception of the fog lights not coming on at all. Everything is hooked up tight. It is a programming thing??
ZL1 Front Fascia, Rockers, & Diffuser, LED DRLs and Fogs, 1LT/RS badges from EmblemPros, CAI Intake, Vmax Ported Throttle Body, Stainless Works Long Tube Headers and Cat-Back Dual Tip Exhaust, IPF Tune, TF3 style stripe kit, Black OEM high wing spoiler, trunk lid blackout stripe, Nitto Motivo tires, 20" Niche rims, and more to come!
Cmitopgun is offline   Reply With Quote
Old 06-14-2013, 05:45 AM   #7
The Stig
The Stig's Avatar
Do you have the non-RS to RS wiring harness?
Old 06-14-2013, 05:45 AM   #8
The Stig
The Stig's Avatar
Where did you buy the fog light harness from?
Old 06-14-2013, 06:06 AM   #9
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
If I'm not mistaken Offer has 2 hardness, but if you looking to have fogs with drls on, what I did was wire my fogs with the halos that way when halos are on fogs lights too...
Monchy36 is offline   Reply With Quote
Old 06-14-2013, 07:35 AM   #10
CamaroI
Drives: 2010 IOM Camaro
Why dont you just hook them up to switches. This would allow you total control over everything. I have this setup and works great. Have the lower fogs on one switch, Halos on DRL on a switch, DRL on a switch and then Headlight halos on a switch. Works great
Plus very clean and right at your finger tips
CamaroI is offline   Reply With Quote
Old 06-14-2013, 07:39 AM   #11
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Thanks
You got them at different time's right? if so call me i can fix that by replacing the 2 harness, its not hard only takes time.
Old 06-14-2013, 07:49 AM   #12
Cmitopgun
Cmitopgun's Avatar
I got it directly from my local chevy dealer parts center.
Old 06-14-2013, 08:23 AM   #13
The Stig
The Stig's Avatar
Ofer (2SSRS) answered your question in the other thread - so I won't keep this one going.
