JDP Motorsports
Old 06-06-2013, 12:05 PM   #1
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Fuel pump install
Is the kent moore (or similar) lock ring wrench required to get the lock rings off the fuel tank? Or can I use the old school technique of a hammer and screw driver to turn it?
K32 Camaro is offline   Reply With Quote
Old 06-06-2013, 12:20 PM   #2
blake-b
blake-b's Avatar
Drives: Black 2010
You can use a hammer and screwdriver.
Old 06-06-2013, 01:14 PM   #3
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Beware of sparks. I bought the tool.
Iam Broke is offline   Reply With Quote
Old 06-06-2013, 02:11 PM   #4
Kelly@PCMofNC
Drives: 2010 RS/SS
The KM tool makes it a million times easier, but you can do it the old school way. Use a brass punch and careful about sparks around fuel vapor!
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
Old 06-06-2013, 02:17 PM   #5
1sick7
Drives: 2012 camaro convertible ss
I wouldnt waste money on tool , its super easy with hammer and screw driver , are you droping it from the bottom or cutting open a door lol ?
1sick7 is offline   Reply With Quote
Old 06-06-2013, 05:03 PM   #6
K32 Camaro
V8 lounge member #5
Dropping it out. I have pfadt solid subframe bushings and a 4" aluminum ds to do at the same time.
Old 06-06-2013, 11:34 PM   #7
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
The lock ring can definitely be removed easily with a brass punch and hammer. Installing it with said hammer and punch was next to impossible. I had to enlist the aid of a long extension. I had to brace the tank on the garage floor, place the extension on one of the lock ring tabs, lean into that with my chest, while using the hammer and punch on the opposite side of the lock ring. After inventing some new curse words, I finally got it to lock into place. My opinion, the tool is worth it, BUT not necessary. Good luck!
734RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 06-07-2013, 12:12 AM   #8
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Hammer and screwdriver work just fine for me. I've removed mine a few times since my squash pump float is bad or something. Damn thing has left me stranded 3 times!
DarkCry956 is offline   Reply With Quote
Old 06-07-2013, 01:10 AM   #9
K32 Camaro
V8 lounge member #5
^ Oh that sucks. I was just contemplating returning my LPE for a Squash cause if I end up blowing this motor the lpe won't handle the lsx replacement..
