JUICEDMOTORSPORTS
Old 06-06-2013, 04:26 PM   #1
Frank in MD
Raining Blood
Frank in MD's Avatar
Drives: 2014 SS Performance Sedan
Car threw 2 codes, is in the shop now
I was on my way home last evening where I had to brake hard. Yellow light, red light camera intersection. Anyway, I felt the car running rough and my dash began to light up like a Christmas tree. Engine light, Service Stabilitrack light, traction control disabled, abs.... I went a block further and pulled it over, Onstar gave me two codes:
U0401 - ABS TRACTION CONTROL STABILITRAK & P0300 - MISFIRE.
I have a '12 1SS/RS. I just had new 22" wheels and tires put on last Thursday. It was a staggered set up. 22x9 fronts 22x10.5 rears.
I'm thinking all my current issues are related to the new wheels and tires?
Thoughts?
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured
Frank in MD is offline   Reply With Quote
Old 06-06-2013, 05:15 PM   #2
Frank in MD
Raining Blood
Related?
http://www.camaro5.com/forums/showthread.php?t=130034
Old 06-10-2013, 03:10 PM   #3
Frank in MD
Raining Blood
Misfire, cylinder #5. How in the hell does that happen at the very same time my dash lights up like a Christmas tree after a hard stop?
Old 06-10-2013, 05:33 PM   #4
Frank in MD
Raining Blood
My svc team thinks the misfire in cylinder 5 is the cause of the Stabilitrack, ABS, Traction Control. I was thinking it was the other way around.
Has anyone ever had an issue where a misfire cause stabilitrack, abs, and trac to light up like Christmas in Times Square?
Old 06-11-2013, 12:51 PM   #5
Frank in MD
Raining Blood
So my car is out of the shop, waiting to get my ticket written up and talk to the tech and the svc advisor. Happy to have my car back but unhappy that the source of this issue was not discovered.... at least as far as I know.
Old 06-11-2013, 07:52 PM   #6
Chevrolet Customer Svc
Drives: GM Vehicles
Appreciate the updates,
Please keep me updated on whether your concern continues to occur or not. Appreciate it!
William R.
Chevrolet Customer Care
Old 06-13-2013, 10:15 AM   #7
Frank in MD
Raining Blood
So apparently, my issue was this:
http://www.camaro5.com/forums/showthread.php?t=233810
Was there ever a TSB for this issue?
Old 06-27-2013, 11:23 PM   #8
NateSS
1337 AH64D driver
NateSS's Avatar
Drives: 2010 Camaro 2SS/RS L99
I'm having a similar issue now...
service stabilitrak, rpm needle stays at zero, and all the traction lights are on.
car will start, but barely.
Cam/Heads by ARD, Tune by G-Force, Transmission/Gears by Circle D
NateSS is offline   Reply With Quote
Old 06-28-2013, 12:00 PM   #9
Frank in MD
Raining Blood
I never had an issue w/ the tach. I just had a misfire from a loose spark plug wire on cylinder #5. When it was switched to another cylinder the issue did not reoccur. Everything has been fine since though. *fingers crossed*
Old 07-30-2014, 08:53 PM   #10
Urbs1391
Urbs1391's Avatar
Drives: 2012 45th SS
Stabilitrak on, no rpms, barely starts.
Mine just started doing this, did you ever figure it out?
Urbs1391 is offline   Reply With Quote
Old 07-31-2014, 01:37 AM   #11
derklug
derklug's Avatar
Drives: 12 Boss 302
When you get multiple warning lights, you have to understand how all of these systems interact. The Stabilitrack, traction control, and ABS all link to the engine controls. When you enter into a sideways slide, a loss of traction, or a skid the ABS computer commands the engine to decrease power. If the engine is missing, decreasing power could cause a stall. So, when the ECM registers a misfire code, it turns on the Check Engine Light and sends this information out to the ABS module. The ABS module then turns off the traction control and Stabilitrack and tells the instrument cluster module to turn on all of the warning lights.
Working together, all of the systems on modern cars make them the safest in history, but a problem in one will effect all of the other systems.
The biggest mistakes in life come when you know exactly what you are doing.
derklug is offline   Reply With Quote
