BORLA
Old 06-06-2013, 08:06 PM   #1
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
Drives: '10 Black Camaro
AC Problems Again!
Not sure why, but I got water shooting out the center AC vents. I can hear water either dripping or running in there. Also it takes a good ten minutes before the real cold air comes on. It's cool, but not cold. Any ideas?
Tx1Lt is offline   Reply With Quote
Old 06-06-2013, 08:19 PM   #2
NOT URSS
NOT URSS's Avatar
Drives: 2010 2SS/RS Camaro
Send a message via AIM to NOT URSS
is it water or coolant? Did you check your ac drain to see if it was clogged?
632RWHP/556RWTQ
NOT URSS is offline   Reply With Quote
Old 06-06-2013, 08:25 PM   #3
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
Definitely water. Where is the AC drain?
Old 06-06-2013, 08:27 PM   #4
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
Here's a pic
Old 06-06-2013, 08:28 PM   #5
NOT URSS
NOT URSS's Avatar
Is the car left out in the rain? just asking
632RWHP/556RWTQ
Old 06-06-2013, 08:32 PM   #6
NOT URSS
NOT URSS's Avatar
Not saying this is your problem, but as i'm still at work i'll give this to you.
2010 Chevrolet Camaro | Camaro VIN F Service Manual | Document ID: 2907839
#09-01-38-003C: Moisture from Center HVAC Vent when A/C is On, Front and Back Floor Carpet Wet (Realign A/C Drain Tube) - (Sep 12, 2012)
Subject: Moisture from Center HVAC Vent when A/C is On, Front and Back Floor Carpet Wet (Realign A/C Drain Tube)
Models: 2010-2013 Chevrolet Camaro
This bulletin is being revised to add the 2013 model year. The Correction has also been updated to provide better clarification on how to access the grommet. Please discard Corporate Bulletin Number 09-01-38-003B (Section 01 – HVAC).
Condition
Some customers may comment that when they have the A/C on, they feel moisture coming from the center HVAC vent. They may also notice that the front and back floor carpet is wet.
Cause
This condition may be caused by a collapsed A/C drain grommet (example shown above), resulting in a buildup of water in the HVAC module.
Correction
Remove the A/C drain pass-thru grommet and realign the drain tube using the procedure listed below.
Note: If the carpet is wet, it must be removed and dried.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in SI.
Support the transmission with a suitable transmission jack.
Remove the transmission mount bracket (support) bolts (1).
Slightly lower the transmission. This will allow access to the HVAC drain tube and grommet.
Reach above the transmission on the passenger side for automatics (shown above) or on the drivers side for manuals until you feel the HVAC drain tube and grommet.
Remove the HVAC drain tube grommet. Let any/all of the water drain out completely.
Important: Only apply a small amount of grease. Too much grease will cause another restriction in the drain tube.
Apply a small amount of grease, GM P/N 12345579 (in Canada, use 10953481) around the circumference of the HVAC drain tube and grommet (1).
Important: When installing the HVAC drain tube and grommet, make sure they are properly aligned to allow the HVAC water to drain properly.
Reinstall the same HVAC drain tube grommet. Make sure the drain tube is properly centered in the grommet.
Raise the transmission and reinstall the bracket (support) bolts.
Tighten
Tighten the bolts to 58 Y(43 lb ft).
Lower the vehicle. Let the vehicle run with the A/C on.
Perform a final inspection for the A/C and verify that the system is draining properly.
632RWHP/556RWTQ
Old 06-06-2013, 08:58 PM   #7
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
Holy crap! That's it! I was wondering why the hell the floor in the back had been wet. I thought my toddler kept dropping his water back there!
Old 06-06-2013, 09:00 PM   #8
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
Taking it to the dealership ASAP. Thanks again!
Old 06-06-2013, 09:04 PM   #9
NOT URSS
NOT URSS's Avatar
I would take it into the dealer if you still have 3/36K in effect or if you have extended like GMPP, Zurich, ect ect.
632RWHP/556RWTQ
Old 06-06-2013, 09:13 PM   #10
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
I have 33k clocked in, gonna take it in under warranty for sure.
Old 06-06-2013, 09:14 PM   #11
NOT URSS
NOT URSS's Avatar
Great! Let us know how it goes.
632RWHP/556RWTQ
Old 06-06-2013, 10:28 PM   #12
Chevrolet Customer Svc
Drives: GM Vehicles
Keep us updated!
William R.
Chevrolet Customer Care
Chevrolet Customer Svc is online now   Reply With Quote
Old 06-06-2013, 10:39 PM   #13
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
Originally Posted by Chevrolet Customer Svc View Post
Keep us updated!
William R.
Will do! This is why I love forums.
Old 06-06-2013, 11:07 PM   #14
Drives: GM Vehicles
No problem!
We're here to keep as many smiles on our customers' faces as we can.
William R.
