Old 06-07-2013, 08:24 AM   #29
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
Originally Posted by ZWA SS View Post
I must not read enough forums. I have never seen/heard of an L99 making 415hp from factory.
But if its on the Internet, it must be true..
Reason for that is that is there was confusion about the new auto Chevy ss had 415hp. I think it was later discovered it wasn't a l99 engine but a LS3
FaytalsCamaro is offline   Reply With Quote
Old 06-07-2013, 08:26 AM   #30
FaytalsCamaro
I could also be completely wrong though
Old 06-07-2013, 08:35 AM   #31
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
Originally Posted by 62nalide View Post
If it makes you sleep at night ok , I have a family member working for GM that can prove 13s are making more, the 14 L99s will be rated @ 415hp same as the new chevy SS.
The Chevy SS uses a LS3 not L99.
CamaroTom is offline   Reply With Quote
Old 06-07-2013, 09:03 AM   #32
FaytalsCamaro
Also I can see 13s making a few ponies maybe. Weren't they the first to introduce electric steering. Or was that 2012
Old 06-07-2013, 09:09 AM   #33
FaytalsCamaro
Dynos are also not so much a tool to show you where you currently stand. But moreso how much of an increase you have gone through. Otherwise all Dino's would be standardized and would measure the exact same. Unfortunately...they don't. Unless GM changes the ratings on the l99 it will remain the same. Remind me did they ever change 2010 ratings for the v6? I'm sure they did cause they said they were using the cts ratings if I'm correct
Old 06-07-2013, 09:13 AM   #34
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
I don't understand why people continue to try and fix people here.
Stock Camaro SS rating:
L99= 400
LS3 = 426
That all, carry on with your FRIDAY
FSP tuned: 377/389
Old 06-07-2013, 09:22 AM   #35
62nalide
62nalide's Avatar
Drives: 2013 SS
OK I retrack my post, just keep in mind the LS3 on the Chevy ss makes 415hp which makes the L99 ss less attractive. The 14s will get a bump the 13s DNA will be in them might not be rated from GM.
62nalide is offline   Reply With Quote
Old 06-07-2013, 09:23 AM   #36
62nalide
62nalide's Avatar
Drives: 2013 SS
Yes, I am aware of that. the 14 L99 will get a simalir HP bump,
Old 06-07-2013, 09:23 AM   #37
nyrfan
Let's go Rangers!
nyrfan's Avatar
Sorry but have to at this.
I can see it now:
Me: Do you have an L99 Camaro I can look at?
Saleman: We do. But we also have an overpriced, 4 door sedan, the new SS. It has an LS3 and has 15 more HP then the Camaro. Might not look as good but it does have 15 more HP!
Me: Sold! I'll take the SS
FSP tuned: 377/389
Old 06-07-2013, 09:46 AM   #38
62nalide
62nalide's Avatar
Drives: 2013 SS
I can see it now:
Old 06-07-2013, 10:06 AM   #39
HeavyIOM
HeavyIOM's Avatar
Drives: 2010 SS, 2000 Pontiac Formula
Some people lol...
My dealer told me my SS has 450 HP so it must be true! They added the boddy kit that helps push the weight lower to the ground so it doesnt have to work as hard. Thats why i have 24 HP more then a normal SS.
Believe it or not i have actually been told that before by someone.
Seriously though just because your car dynoed 5 HP more then someone with a 2012 doesnt mean the rating changed from GM.
HeavyIOM is offline   Reply With Quote
Old 06-07-2013, 10:08 AM   #40
Camper
Banned
Drives: 10' 2SS LS3 M6
shut up
Camper is offline   Reply With Quote
Old 06-07-2013, 10:24 AM   #41
62nalide
62nalide's Avatar
Drives: 2013 SS
Originally Posted by Camper View Post
shut up
Old 06-07-2013, 11:08 AM   #42
wakespeak
wakespeak's Avatar
Drives: 2013 2SS LS3/NPP
432hp vs 426hp = + 1.4%. Probably within EPA tolerances and not worth raising a fuss over in the US.
Otherwise could be a different tune since European fuels have higher octane.
wakespeak is offline   Reply With Quote
