Emblempros
Old 06-06-2013, 08:44 PM   #1
HellHound
HellHound's Avatar
Drives: 2010 Camaro SS M6
Thoughts on these cam specs for LS3?
I'm fairly new here and don't post often, I'm more of a reader and just take the information in.
Anyways for the most part I'm pretty dead set on my cam selection and already have the Cloyes LS2 (3 bolt) timing set up.
Lunati has a few Voodoo grinds that I am interested in, the only catch is the grind that intreges me the most is a LS1/LS2/LS6 cam (3 bolt)
Lunati Voodoo #60512
Hydraulic roller. Serious street/strip cam. Requires computer modifications. Needs upgraded intake manifold, exhaust maximize performance.
  • Advertised Duration (Int/Exh): 282/288
  • Duration @ .050 (Int/Exh): 232/238
  • Gross Valve Lift (Int/Exh): .599"/.601"
  • LSA/ICL: 113/109
  • Valve Lash (Int/Exh): Hyd/Hyd
  • RPM Range: 2400-7000
9* of overlap
My brother has had excellent results out of these grinds in his GTO and carried a great torque curve, although it is cathedral port.
I'm not posting this to get bashed on my possible selection, just looking for some useful info and to see if anyone else has had experience with a LS1 cam in with the L92 setup.
Lunati states the difference from a LS1 grind to a LS3 is no different other than the specs itself, to benefit the exhaust with the larger rectangular intake port.
To be honest I think the large duration splits are a somewhat overrated from speaking with Lunati/Comp techs and seeing some Pat G testing. The 6 degree split this cam offers should be sufficient enough. Similar to the TSP 231/236 that I have seen success with on here. RPM range seems to be right in the ball park, and the lift is what I want for street use. I understand these Voodoo cams have a asymmetrical lobe, which has a fast aggressive opening ramp rate and softer on the closing side to be easier on the valve train.
Obviously I will be using the correct supporting mods, valve-train, 1 7/8 LT's, FAST 102, Ported TB, etc.
Thanks in advance.
HellHound is offline   Reply With Quote
Old 06-06-2013, 09:07 PM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
This cam should be a solid performer, I would say its capable of 460s rwhp on a ls3. The lower lift will leave a little power on the table, but the cam should have a good flat tq curve and good average power in general. It won't be a real peaky cam, but it will be a great daily cam.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 06-06-2013, 09:42 PM   #3
HellHound
HellHound's Avatar
Appreciate the response. That's what I'm going for to be honest. A strong street cam that makes good bottom end with a broad power band maybe the 102 will get me a couple ponys up top.
How much does the LSA and ICL play into the L92 game?
Old 06-06-2013, 09:42 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
But just edit your post to 9* of overlap bud.
Old 06-06-2013, 09:43 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I doubt the FAST will yield any at this level bud. Ls3 is up for the task.
Old 06-06-2013, 09:47 PM   #6
HellHound
HellHound's Avatar
I'm sorry I must be determining a different number.
I see now. I used the advertised number.
Ex Closes- 2 ATDC + Intake Opens- 7 BTDC= 9*
Old 06-06-2013, 11:13 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Lol gotcha no biggie.
Old 06-07-2013, 08:40 AM   #8
Alvin@PCMofNC
Drives: 2010 IOM RSS
If it was me I would go into the mid 240's on the exhaust with that much intake duration alone. If not pull the intake lobe into the low 220's. There isn't enough split there to really take advantage of what could be there.
Alvin@PCMofNC is offline   Reply With Quote
Old 06-07-2013, 09:28 AM   #9
KCS
KCS's Avatar
Drives: 2000 Pontiac Trans Am
I couldn't agree more. We use relatively small intake lobes and pretty normal exhaust lobes on the rectangle port heads compared to something we would spec out for a cathedral port head. Some of our blower grinds have as much as a 20 degree split between the intake and exhaust...
KCS is offline   Reply With Quote
Old 06-07-2013, 10:11 AM   #10
CGT
Drives: 2011 SSm6
I think that cam will be just fine, using exhaust flowbench cfm as a basis for choosing exhaust duration or a difference or "split" can lead you down the wrong path. That being said, the larger "splits" can work well, just not for the reasons people think they do. It has alot more to do with Exhaust valve opening and overlap positioning than "flow differences".
CGT is offline   Reply With Quote
Old 06-08-2013, 07:54 AM   #11
Rhino79
Rhino79's Avatar
Is the industry standard now overlap at .050, because I always went off advertised numbers for overlap...lol. Maybe Im old scool
My new cam is around 27* of overlap. But at advertised specs its 72*....lol.
Old 06-08-2013, 08:57 AM   #12
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
  • LSA/ICL: 113/109
9* of overlap
I'm not posting this to get bashed on my possible selection, just looking for some useful info and to see if anyone else has had experience with a LS1 cam in with the L92 setup. I'm sure my PTV would be fine as well?
To be honest I think the large duration splits are a somewhat overrated from speaking with Lunati/Comp techs, and the 6 degree split this cam offers should be sufficient enough. Similar to the TSP 231/236 that I have seen success with on here. RPM range seems to be right in the ball park, and the lift is what I want for street use. I understand these Voodoo cams have a asymmetrical lobe, which has a fast aggressive opening ramp rate and softer on the closing side to be easier on the valve train.
Thanks in advance.
This is What we call a Carry over Cam, There was a Lot of money allocated for developing Cams for the LS1 when it hit the streets.
R&D Cost money that must be spread out over many cam sales in the Thousands before it is paid for.
Even the description is a dead ringer for the LS1, They Benefited most from Intake manifold upgrades.
Where the LS3 intake is So Good It doesn't.
Will it work Yes, Is it Optimal for an LS3/L99 NO
We did all of our R&D on the LS3/L99 for our Cam Lobe Profile selections, and Lobe separations.
We studied the Head First to come up with a baseline then proceeded to test our Theories, We had our Failures and our Success which lead to our Cam Shaft offerings in Rough Idle and Smooth Idle.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 06-08-2013, 10:10 AM   #13
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You had me at 27* rhino! Lol I love it already.
Old 06-08-2013, 10:37 AM   #14
HellHound
HellHound's Avatar
Thanks for some educated responses guys. All this info factors into my decision. obviously the LS1 to LS3 specs are going to differ as far as duration, lift etc. I was always curious of if, the manufacturer made adjustments in the grind itself, maybe even changing the ramp acceleration in certain areas....or allowing possibly a higher max lift area in general.....
I have always been impressed in the results from the 231/236 that TSP offers, just not fan of the high lift for street use and long commutes, over a period of time and working the valve-train so much. Maybe I'm just trying to find a cam in the brand I am partial to, to mimic the TSP cam, although obviously sacrificing some lift.
