Old 06-06-2013, 10:31 PM   #1
cuffnstuff1
Drives: Hearse
Too Much Oil?
First oil change 2012 ss/rs I filled up oil filter prior to installing. while putting in the mobile 1 oil I thought there were gallon=4 quarts. on my second one "gallon" I noticed there 5 quart containers. so I stopped with about a quart left in the container. I started it for a min then shut it off let it set for a few min and checked the oil and noticed it right at the top of the XXXXXX marks maybe a hair over.
Im going on a long road trip in a few days, my car has 4k miles on it
Should I drain a little out or will it be ok?
cuffnstuff1 is offline   Reply With Quote
Old 06-06-2013, 10:33 PM   #2
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
I think you will be fine, do you have a catch can? I think that might help with assuring that it will be ok too.
AmericanMuscleCars is offline   Reply With Quote
Old 06-06-2013, 10:33 PM   #3
NOT URSS
NOT URSS's Avatar
Drives: 2010 2SS/RS Camaro
Send a message via AIM to NOT URSS
You be ok
632RWHP/556RWTQ
NOT URSS is offline   Reply With Quote
Old 06-06-2013, 10:34 PM   #4
cuffnstuff1
Drives: Hearse
no catch can yet was doing a few other mods that was my next investment
Old 06-06-2013, 11:11 PM   #5
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
No worries.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 06-06-2013, 11:18 PM   #6
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
That's full to me.
MYDLIFECRISIS is offline   Reply With Quote
Old 06-07-2013, 12:02 AM   #7
AmericanMuscleCars
I'd say get a catch can before any other mod. After all whats the point of having all of those performance enhancing mods and the carbon build up is contradicting the mods and decreasing the overall horse-power, it only takes 30 minutes to install.
Old 06-07-2013, 12:05 AM   #8
cuffnstuff1
Drives: Hearse
what's a good brand that's not to expensive
Old 06-07-2013, 12:33 AM   #9
AmericanMuscleCars
Well, I am getting a catch can made by elite engineering from apex speed. its is 165 dollars with free shipping. The elite catch can is just as good as the other ones. But if you get a cheap one, you might as well not even use one. A quality catch can is well worth it because if you don't get a quality one you might as well use a coffee filter. I believe a quality one is a good idea. If you intend on keeping your car for your whole life span and driving it on long trips like you are then I would just get a good quality catch can like the elite engineering. And if you can afford it overnight it so you can put it on before your trip. But if you can't get it on by your trip thats fine it should be waiting for you by the time you get back. For the money the elite engineering catch can is an awesome catch can, here it is: L99: http://www.apex-speed.com/elite-engi...c-300-l99.html
LS3: http://www.apex-speed.com/elite-engi...c-300-ls3.html
Old 06-07-2013, 09:10 AM   #10
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
How often do you check/change a catch can? say, in 4000 miles of driving...worse in stop and go or highway?
Glen e is online now   Reply With Quote
Old 06-07-2013, 08:48 PM   #11
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
It depends on how well the rings seated during break in as to how much oil blow by you will get.
now with that in mind I drain my RX catch can about every 3000 miles. I only get about a teaspoon full. your results may vary.
GVA 45TH 2SS is offline   Reply With Quote
Old 06-08-2013, 07:16 AM   #12
spike III
COTW 6/25/12
spike III's Avatar
Elite & Rx in my opinion are the best,I have them both. Checking your oil normal-if you see a drop in level check catch can. I check mine often cause of the way I drive. But always check when you change oil & empty it. The Rx from JDPmotorsports is $139 Painted the color of the car.
spike III is offline   Reply With Quote
Old 06-08-2013, 08:14 AM   #13
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
So you put in 9 or more quarts instead of the required 8. Check your oil again after your car sits for a while. Myself if I did this I would be draining some out.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 06-08-2013, 08:24 AM   #14
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
The easy way to drain a bit of oil is to change the filter and don't pre fill it. That will get almost a quart out.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
