BORLA
Old 06-06-2013, 10:04 PM   #1
CamaroDIYking
Drives: 2010 Camaro 2SS/RS
quad tips?
would the quick tips fit in the factory GFX kit on a 2010 Camaro? im curious...
2010 2SS/RS- every option possible in 2010
Lighting- LED footwell, grille, trunk, and engine lights done via DIY. LED dome, DRL, and tag lights.
Paint- Painted engine cover, steering wheel bezel, speedometer bezel, front bowtie, tail light bezels, wheel center caps.
Exterior lights- tinted tail lights and sidemarker lights.
Wheels- powdercoated stock RS 20' wheels black
Exhaust- Cat-back Dynomax Bullet Exhaust system with bullet muffler delete.
Misc- rear blackout kit from Big Worm Graphix, black side Camaro lettering from Emblem Pros, and rear Camaro lettering from Emblem Pros.
CamaroDIYking is offline   Reply With Quote
Old 06-07-2013, 02:20 AM   #2
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
I believe you would have to take a dremel to it, which isn't necessarily bad, it just takes a little bit of work, a steady hand, and focus. But stock, i don't believe it would fit.
AmericanMuscleCars is offline   Reply With Quote
Old 06-07-2013, 05:01 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
You cannot dremel the gfx diffuser.
OP: I've seen it done once and
1- Couldn't figure out the point as they are in the diffuser
2- Looked stuffed in the holes.
FSP tuned: 377/389
Old 06-07-2013, 05:17 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
I don't think the factory quad tips will but Stainless Works makes a quad tip that is designed to fit the GFX opening.
