Gen5DIY
Old 07-17-2009, 09:03 AM   #15
Ron@Vengeance
Ron@Vengeance's Avatar
Drives: 2013 Artic White GrandSport
I think you are going to be more than happy Alex!!!!
Ron@Vengeance is offline   Reply With Quote
Old 07-22-2009, 02:06 AM   #16
kellertxgen5
kellertxgen5's Avatar
Drives: 2LT RS - Black w' black 21's
No dyno with the cam?
Black 2LT RS w/ Black 21's Driving since 7/17
kellertxgen5 is offline   Reply With Quote
Old 07-22-2009, 04:09 AM   #17
BlueMarlin
phi alpha
Drives: 2005 GMC Envoy
Wow, thats pretty cool. This is the second time I've put this up here tonight:
Name:  i want it regular sized.gif
BlueMarlin is offline   Reply With Quote
Old 07-22-2009, 10:53 AM   #18
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
The after cam dyno is in post 12.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 07-29-2009, 09:53 PM   #19
grngryoutmyway
Drives: 92 RS
Hey, thanks for stopping by NAPA today. Your car was a nice break for us at work for a bit. Looked, and sounded killer man. If we can help you out with anything just let us know.
Thank goodness for On Star
grngryoutmyway is offline   Reply With Quote
Old 07-29-2009, 10:37 PM   #20
themossman
themossman's Avatar
Yeah..that was pretty funny!
For those that haven't tried it...I did an impromptu demo of how OnStar can unluck your car when you've locked the key in the car WHILE THE ENGINES RUNNING! Nice...
It was a pleasure meeting you guys.
Current Summary:
Old 07-29-2009, 11:36 PM   #21
themossman
themossman's Avatar
Radar Detector Hardwire Install-Escort 8500
The following install outlines how I hardwired my passport into a power source located in the headliner that is only on when the ignition is on....I did this in my M3 and my wifes 530...and had to do it in my Camaro...I just wish one of you guys had done it first so I had a guide!!!!
***Note...this DOES NOT include a remote control module for the mute...I don't need it as the escort has auto mute.
The picture quality sucks because it was my blackberry, but beggars can't be chosers!
First step is to gain access to the interior of the headliner. Patience is key here as these parts were made to be installed easy...not taken apart easy. All of this can be done without gorilla force...keep that in mind....
First...the tools you'll need:
1. Wire stripers
2. Small flat head screwdriver...I call them 'tweakers'
3. Pliers
4. Regular Phillips head screwdriver
And some 'parts' you'll need (all can be found at Radio Shack):
1. Black phone cord (I used one left over from sat tv install, the cable is round as opposed to flat and that worked out for me)
2. Wire taps (see picture)
Phone cord (notice only TWO wires..red and green...that's all you need)
Wire taps (these worked EXTREMELY well):
http://home.comcast.net/~awmoss/Radar/IMG00104.jpg
Ready...here we go!
First step is to remove the lens from the overhead lights. I started on the right side with a little tweak...then on the left...the towards the middle/front...then back....
Next is the little silver reflector...same process...DON'T MUSCLE IT...be patient...
This next part is the hardest part...the mother of all evils. The white part has to come out and there's two pressure clips holding it in and the clips are towards the front of the car. It would work best if you had two tweakers and a partner lend an extra hand...each of you pushing in one clip. The clips are toward the front of the car and you can depress them by sliding your tweaker in the hole. Look at these pictures...study the part...then reread what I just wrote. This can be a pain to remove...be patient and don't tear up your headliner.
The next part requires your phillips head...remove the two screws you see here...
With the screws out, the entire bezel is ready to come out. This piece is held in place with four clips. This does require some targeted pressure to remove...don't tug on the edges...reach inside the 'hole' you made by removing the light and feel where the clips are and you'll be fine. Pull all four clips out and the piece comes out with wires attached. The pics below will show you what the clips look like and where they are.
Unplug the harness from homelink(if you have it), unplug the onstar mic, and unplug the airbag light.
The only wire that carried constant voltage when the ignition was on, and dropped voltage when the ignition was off was one of the wires for the airbag/seatbelt indicators...so this is the wire I tapped into. I removed some of the wire fabric tape so that I could tap into the pink wire for the power and the black wire for ground.
A picture of the tap...
Tapping in..
All tapped in...
Prepping the phone cord...cut off one end and strip the two wires. Attach the connectors for the taps.
Now PLUG EM IN!
Remember RED GOES TO PINK and GREEN GOES TO BLACK.
Push the plug through the front of the headliner...and funny enough there's a spot that looks like it was made for the cord...fits perfectly. No force here...just gently work it through.
TEST YOUR RADAR DETECTOR BEFORE YOU BUTTON EVERYTHING BACK UP
Now...reverse all the take apart procedures. You'll find it goes together a heck of allot easier than it comes apart.
The following photos aren't great...but they show the finished product.
Gratuitous engine shot...
Current Summary:
Old 08-30-2009, 04:23 AM   #22
Gen5SS
Drives: 2010 SS/RS 6 Spd Manual IOM
Just wanted to thank you for the detailed description, every thing went as you posted except I had to direct wire mine because I think the tap-ins I bought were too big. Great post and thank you for making it easy.
Gen5SS is offline   Reply With Quote
Old 08-30-2009, 11:36 AM   #23
themossman
themossman's Avatar
Great to hear! I should have mentioned that the tap ins need to handle small gauge wire as those phone cord wires are super tiny.
Current Summary:
Old 09-03-2009, 03:21 AM   #24
SILVER BULLITT
Drives: 2010 SIM 2SS/RS MONSTER
DO YOU KNOW WHAT THE CUT IS ON YOUR CAM AND LSO WHAT HP DID YOU GAIN FROM IT ? ALSO HAVE YOU DONE ANYTHING TO THE HEADS ? THANKS JUST TRYING TO GET AN IDEA ! MINE IS GOING UNDER THE KNIFE NEXT WEEK THANKS AGAIN
SILVER BULLITT is offline   Reply With Quote
Old 09-03-2009, 03:00 PM   #25
themossman
themossman's Avatar
Cam info: https://www.vengeancerd.com/ecart/pr....624-115%252b3
I'll have to check with Ron...but I don't think we have a dyno with just the cam. We had a dyno before the cam, and one after cam install with ported intake and tb, ud pulleys, matched injectors, and thermostat.
Current Summary:
Old 09-24-2009, 05:13 PM   #26
bdg
bdg's Avatar
Drives: 2010 camaro
For a bad ass ride.
bdg is offline   Reply With Quote
Old 10-01-2009, 11:48 AM   #27
themossman
themossman's Avatar
Local (Jacksonville) Dyno
Looking at some changes to the car...so I thought I would have a baseline dyno done at a local shop. And...yesterday was the first semi-cool day we had here in a LONG time.
First two pulls were only at ~440 rwhp...and I just noticed that I think the tech was coming off the gas before reaching max RPM's.
Anyway...final pull was consistent with what Vengeance saw in ATL...so I've got a good baseline to work from.
Current Summary:
Old 10-01-2009, 02:15 PM   #28
Ron@Vengeance
Good deal Alex!!! Enjoy the new upgrades
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
2010 sim for sale 2ss/rs jimmyallgm Autos For Sale / Wanted 3 06-28-2009 09:46 AM
2010 2SS/RS Camaro @ my driveway... Mayhem 5th Gen Camaro SS LS LT General Discussions 7 06-01-2009 05:09 PM
Edmunds: 2010 Ford Mustang First Look Scotsman General Automotive + Other Cars Discussion 32 11-23-2008 10:55 PM
2010 2SS/RS Question seventy7camaro 5th Gen Camaro SS LS LT General Discussions 5 10-26-2008 12:33 PM
