SDTW Custom Wheels & Tires
Old 06-07-2013, 06:38 PM   #1
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Bull's F16 Updated
Bull has built an awesome 5th Gen with a bit of power.
He has been running a Pedders Justice Package with 305/30/19s all round. Last week we decided to upgrade to the new rear Z style bar, increase the spring rates to 12kg and add camber plates.
The first step is mission critical. It is the classic example of measure twice. Cut once.
Finding the center line for the camber plates requires only a string and ruler. Once you have the string evenly dividing the strut tower holes on both sides the rest is cake.
We setup Bull's Camaro for maximum adjustment. During the initial installation we relived the upper slots in his Suppercar Coilovers to increase the available negative camber. With his camber plates he won't be using all the available camber adjustment unless we stagger his setup for an oval track. Since Bull drives as hard as his call sign implies we maxed out everything.
We can get to -4.7. The two small holes allow access to the camber plate screws at -4.3 using the slots in the clevis or -2.6 with no camber at the clevis.
Bull Got Camber!
We roughed in the alignment and went to work on corner weights. Bull's Camaro has extra engine stuff including junk in the trunk. We are within 6 pounds or perfection on a 4116 pound automobile without moving weight around the vehicle. The total ride height differences were under 9mm divided between four wheels.
We are within 6 pounds or perfection on a 4116 pound automobile without moving weight around the vehicle. The total ride height differences were under 9mm divided between four wheels. As this is a custom Camaro, the exact ride heights are not relevant to other Camaros. Running 660mm ride heights all round is relevant to all 5th Gen Camaro owners. When all is said and done there was less than 9mm total variation in ride heights to get this balanced.
We did not align the car with just the driver. Bull uses his Camaro as a street car and frequently has a passenger. Be ware of this Camaro when his daughter is driving. From what I can gather she is her father's daughter.
Let's talk alignment numbers.
We maxed out Bull's Caster using Pedders Full Alignment Bolt Kit. Caster is good. SAI is better for steering geometry and feel. We added a 1 point to SAI under all alignment positions. As I type this I just noticed that the Right side Street and Track numbers are wrong. In full track mode we are 14.3 left and 13.9 right. In street mode we are 12.9 left and 12.8 right. The improved SAI SAI is a benefit of installing Pedders Dual Bearing Camber Plates.
For street driving we are TOE in 0.15 on both side. We would like to be closer to 0.00 Toe, but the toe moves out aggressively as we add negative camber. For Bull's use we felt that -1.00 Camber and Toe IN 0.15 was a good split of handling and tire wear for daily driving.
Pedders Dual Bearing Camber Plates are indexed. That is critically important if you want to change camber setting track side and drive home with a tire friendly alignment. Loosen the set screws in the camber plates and you get a track alignment. -2.6 degrees of camber with 0.80 toe OUT. Bull's Camaro turns in and turns in now.
Bull is running Pedders new Z bar and has an enormous amount of power at the rear wheels. We settled in with a comfortable Toe IN of 0.10 per wheel in the rear. Rear camber is a compromise. It would be nice to run more rear camber for high speed mid turn. If we increase the rear camber to -1.3 Bull will burn through rear tires on the street as though they were disposable. Putting all that power down requires a stable IRS. We used EP1201HD bushing for maximum control.
When you look closely at the images and data, it is clear that Pedders delivers a clear upgrade in the control surface areas. Our numbers are conservative. We have ridges in our EP1201 series of bushes so we only calculated the ridged areas - even though they compress when installed.
How does Bull's Camaro drive? I am sure he'll stop by and let you know.
Old 06-08-2013, 12:11 AM   #2
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
That is freakin' WICKED!!!!!
T.
GO HAWKS!!!!!!
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 06-08-2013, 02:03 AM   #3
SPCBA
Drives: pleather and Chiclets
beautiful car Bull.
SPCBA is offline   Reply With Quote
Old 06-08-2013, 02:05 AM   #4
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
NICE! I'm jealous
L99 With a Maggie
Nutro is online now   Reply With Quote
Old 06-08-2013, 02:11 AM   #5
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Very nice man!
CHMSC is offline   Reply With Quote
Old 06-08-2013, 02:15 AM   #6
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
Nice, I need some Pedders in my car.
Sapper12b is offline   Reply With Quote
Old 06-08-2013, 08:19 AM   #7
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Awesome!
jeremywes is offline   Reply With Quote
Old 06-08-2013, 11:21 AM   #8
snickerdoodle
Drives: 2013 1LE AGM 2SS RS M6
I need those wheels.
snickerdoodle is offline   Reply With Quote
Old 06-08-2013, 08:28 PM   #9
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Wow Pete, just saw this!!!
Awesome write up. I've been disposed as a range officer at my local USPSA club. The past 3 days i have been officiating 300 shooters from all around the country and globe for that matter. Just spent 12 hrs today in the Texas sun and wind and 10 hrs yesterday. Match, called Double Tap Championship, ends tomorrow at about 1400 hrs....hopefully. This match is usually the 2nd or 3rd biggest pistol match in the nation. I have to mow my damn yard still.
I will give a write up as to my experience with this latest update to my extraordinary experience with Pedders when i recover a bit later in the week. Let me say the car is on frickin rails, if thats possible for a 4112 lb car!!!! Mine is!!!
Here's a little clip from the DTC match a couple years ago when i was an Range officer on stage 2. You can see my fat arse at the 41 second mark and up to the minute mark on the video of one of the better shooters. My job was to check for safety infractions record the hits and time for scoring purposes. Im in the white shirt with the clipboard.....I love paperwork btw!!! Couldnt find any vids of this years so far or last years but didnt look real hard...time for motrin, beer and bed!!!!!!!!!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 06-08-2013, 08:40 PM   #10
timtoolman24
timtoolman24's Avatar
Drives: 2012 LS3 2SS/RS
Bull we have almost same cars, same power and mods. Looking to get my car on rails!
timtoolman24 is offline   Reply With Quote
Old 06-08-2013, 08:48 PM   #11
BullF-16
BullF-16's Avatar
Call Pedders!!! Read "The Book"..... that's all it takes!
Old 06-11-2013, 11:14 AM   #12
BullF-16
BullF-16's Avatar
Alright, sitting here at work and finally have a few minutes to reply here since it's my car.
Drove down the 5 hrs to Fredericksberg on a Thursday a couple weeks ago. Had an appt with American Muffler and Brake for the install of ZL1 rear sway, new FE4 control arms 12 kg coils and adjustable camber plates.
I had the Justice package with supercar coilovers and sways installed a year and a half ago by the same place. American Muffler and Brake is who Pete and Pedders uses and are located about a half hr from Pedders HQ. If you live anywhere near, it is worth the drive out to see Heath and Jimmy and American Muffler. Pedders uses these guys for a reason. I like them also because they let you get dirty right along with them.
Sure enough, about 4 months after this, Pedders came out with the ZL1 sway bars for the FE3 Camaro. I had it all set up to drive back down for the re-alignment (due to new wheels/tires setup) and the ZL1 sway. Two days prior to this appt. I popped my #5 piston on my factory LS3 running 11psi. Car sat for 9 months waiting for my HKE built LSX 427. Finally got it back on the road.
During the time the car was down, Pedders came out with the new camber plates. I needed this due to the fact that i was runningn -2.5 deg camber 100% of the time. Tires weren't gonna last too long.
So, i ordered the ZL1 sway, 12 kg coils, and camber plates. Huge thanks to JusticeDeb, she busted her ass getting me these 12kg coils sent in record time from Australia!
Anyway, i show up at American Muffler at 0800 Friday morning for the install and alignment. All is going well an hour into when Pete shows up out of the blue to oversee the install!
When we remove the front wheels there is an unexpected development. I have a chord showing on the inside edge of the Bridgestone RE11 Potenza. This was due to running the -2.5 deg camber. Not to worry, Pete gets on the phone and 1/2 hr later we have 4 new Michelin Pilot Super Sport 305/30 R19s on the way from San Antonio. They were due in at 1700 that afternoon, should be plenty of time.....right?
The install goes great, no major hiccups except for the time required to do everything perfectly, which they did. Pete even brought his equipment to perform an corner balance. As you can see above, this car is the epitomy of balance. The alignment took about 3 iterations to get perfect and by the time we finished Discount tire in Kerrville was closed. So i kept my hotel for another night......
Pete would have none of that, so off we drove to his home. Pete set me up right! Even paid for dinner that evening. Then, following dinner was a tasting of various levels of the finest Serbian plum brandys direct from Serbia. Pete is of proud Serbian descent!!! Ziveli Pete.
Next morning we drop the car off at Discount tire and Pete and his Wife Justice Deb and his three wonderful daughters take me to breakfast at IHOP!!!
Where are you gonna find customer service that even comes close to this????
The car is insanely sticky, the only time i have broken it loose is by staying on the throttle in turns when the rear starts to get a little loose, but it is very predictable. The fronts are dead solid perfect and no push at all. I imagine having 305/30 R19s have a little to do with that. Oh, this is all with the camber plates set to my street setup. It only takes about 2 minutes to go from mild to wild and set in the -2.5 deg camber and agressive toe out.
I need to address my braking setup next then take the car out to Eagles Canyon raceway, 2.5 mile road course and see what it can really do.
Thanks again to Pete and Pedders!!!
Old 06-11-2013, 11:51 AM   #13
Ice Demon
Ice Demon's Avatar
Drives: 2010 Camaro SS
Very nice man and can't wait to see how it does on the road course. Also that's some great customer service right there.
Mods: "Cam Only"
Ice Demon is offline   Reply With Quote
Old 06-13-2013, 10:24 PM   #14
BullF-16
BullF-16's Avatar
Forgeline DE3Ps 4 x 19 x 10.5" on all corners. Besides the Pedders suspension, the best mod i have made. Thanks Pete for the recommendation.
This is all you need to know to make this 4000# behemoth act like a damn 2000# Miata.
As you can see the smaller 19" wheels dont look too bad in those gigantic wheel wells.
http://www.camaro5.com/forums/showthread.php?t=37333
