BeckyD@RodgersChevrolet
Old 06-07-2013, 10:51 PM   #1
Khmero215
Khmero215's Avatar
Drives: Victory Red 2SS
injector help
I was told I'm at my max on my stock injectors. what do you guys recommend? I am currently running a TVS2300, LSR cai and will soon have TSP 2" headers. I was lasted dynoed at 525 rwhp. my local speed shop recommended I get my stocks re-flowed(cheapest way). Point me to the right direction
Khmero215 is offline   Reply With Quote
Old 06-07-2013, 11:10 PM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Id 850s
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 06-07-2013, 11:11 PM   #3
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
Most people on here will tell you Id 850s are the best. Expensive but worth it I run a fast 850 , about half the price ,and seems to work alright. Motor rocks. I do have a bit of a sporadic idle issue ( hunts a bit). Tuned by two seperate tuners both professionals so problem could be something else. I
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
bcguy is offline   Reply With Quote
Old 06-07-2013, 11:14 PM   #4
Aqua_Blue_SS
Aqua_Blue_SS's Avatar
Drives: 2010 ABM 2SS/RS M6
I have the tvs and going with id850's and new fuel pump
Aqua_Blue_SS is offline   Reply With Quote
Old 06-07-2013, 11:32 PM   #5
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
I'm running the FAST 65 injectors and I'm currently at 93% capacity. Should be fine for your power level.
gnturboray is offline   Reply With Quote
Old 06-07-2013, 11:43 PM   #6
epstein
Drives: SS/RS
Send a message via AIM to epstein
Fuel Pump....... ADM FPCM...... and ID 850's........in the long run your motor will thank you
epstein is offline   Reply With Quote
Old 06-08-2013, 12:01 AM   #7
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I run FIC injectors, IDs are great, but they aren't the only ones out there that can put fuel in a cylinder. Go for the GM LS9 injectors, they'll cover up to 600whp and will be a cheaper option than most anything. Expect to pay around 250 for a set.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 06-08-2013, 02:32 AM   #8
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
This
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 06-08-2013, 07:18 AM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Originally Posted by Kronix View Post
This
That.^^^^
Mchlgrrsn is offline   Reply With Quote
Old 06-08-2013, 07:53 AM   #10
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
^^^and not the other thing
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 06-08-2013, 08:13 AM   #11
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Your TVS2300 Came with 52 lb per hour LS9 or ZR-1 injectors.
When it comes to injectors there is only one choice Injector Dynamics ID-850s.
This will be debated by many, but Those in the Tuning Profession and Those who have been Through several sets of injectors will all Agree.
Better to purchase 1 Great set of injectors then to purchase many Cheap sets along the way.
They will support up to 1200 Crank HP, and Idle and Drive Like Factory injectors.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 06-08-2013, 09:10 AM   #12
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Ted.
Very good advice, as always. I tried a set of FIC 60's (72 lb/hr @ 58 psi) and wasn't pleased. Sold 'em and went with ID850's.
Iam Broke is offline   Reply With Quote
Old 06-08-2013, 09:30 AM   #13
SC2150
As Ted states, any re-drilled we see on our flow machine
The spray pattern is rough, uneven, and allowing droplets...not good. The iD's are a beautiful consistent atomized spray.....and that makes all the difference in the world as any droplets will not burn completely or evenly.
Old 06-08-2013, 10:37 AM   #14
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
i have my FAST 65lb injectors for sale too if your interested. Just made 622whp /590tq with them.
If you are planning on continueing for the power increase journey, then ID850's are where its at. Thats what i am saving up for because i am in the hunt for 800whp.
But if you are just looking for a little room to grow let me know.
xjer22x is offline   Reply With Quote
