Old 06-08-2013, 06:25 AM   #1
SSRS1LE
Drives: 2013 Camaro 2SS/RS/1LE
DIY: Disable 2013 HSA (Hill Start Assist)
Like many of the 2013 manual-transmission owners, I have found HSA to be a nuisance that interferes with the smooth operation of the vehicle. Unlike Hill-Assist implementations in other cars, which can be turned on or off, there is no way to disable this feature on the Camaro without modification to the vehicle.
My method of disabling HSA, was to replace the Yaw-Sensor, with the part number used for the Automatic Camaros. This sensor does not have the longitudinal-accelerometer that triggers HSA. After installation, the car had no warning lights or warning messages. HSA no longer activates, nor does the Hill Start message ever appear.
Special thanks to MPHS_AGM for some key-info on HSA functionality, and to OzzySS for specifics on the sensor location. Also thanks to jtzako for his guide on PDIM + USB Port installation, as I followed this guide for center console disassembly.
Disclaimer: As with all modifications and DIY articles, perform any modifications to your car at your own risk. The author assumes no responsibility for your actions.
Parts Used
GM Part# 13578326 - Yaw Sensor without Longitudinal Accelerometer
Tools Used
  • 7mm Socket
  • 10mm Socket
  • Phillips Screwdriver
  • Small Flathead Screwdriver
Step 1 - Remove the center Console
As mentioned, I followed jtzako's excellent guide for removing the center console. http://www.camaro5.com/forums/showthread.php?t=77662
Removal is the same for manual-equipped Camaros.
Step 2 - Remove and Replace the Yaw-Sensor
Once the console is removed, the yaw-sensor can be located to the left of the emergency-brake. Simply remove and replace this unit with GM Part# 13578326 using a 10mm socket.
Put everything back together, and you're done. No more Hill-Nanny!
____________________________________
Modifications: HSA Elimination - Cold Air Inductions Intake
Solo Performance Mach Cat Back - Skip-Shift Eliminator
SSRS1LE is offline   Reply With Quote
Old 06-08-2013, 07:22 AM   #2
Combover
Combover's Avatar
Drives: 2013 ZL1
Thank you very much!
Would like to hear if you notice any onther changes. I hope GM takes notice of what owners are willing to do to disable HSA, and retrofitsa software change allowing the disabling of this feature.
Combover is offline   Reply With Quote
Old 06-08-2013, 08:01 AM   #3
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
I think you are about to make many people very happy!
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 06-08-2013, 08:37 AM   #4
racerx1214
Drives: 2013 1LE
Stabilitrak still work?
This is genius if it still does.
racerx1214 is offline   Reply With Quote
Old 06-08-2013, 09:13 AM   #5
RoadieWingZ
RoadieWingZ's Avatar
Drives: 2013 Black Camaro 1LS
Good question. If the orientation of the sensor still includes the "yaw" aspect of the three directional movements (pitch, roll, yaw), then I'd think all is well. The notation of it not having longitudinal sensor indicates the "pitch" movement is absent which would correlate to the concept of the nose facing up or down a hill. Therefore, the stabilitrack function, which I think is principally a yaw motion protection, should be ok. Someone with the mod should find a big wide open parking lot on a wet day and try to drift the back end to see if the stabilitrack control kicks in.
Me, I'm keeping the HSA as it seems to work perfectly for me on all the hills around Austin...
2013 Camaro LS
RoadieWingZ is offline   Reply With Quote
Old 06-08-2013, 03:57 PM   #6
Eich
Drives: '11 SW/Beige 2SS RS Manual
It works in an automatic car. I would expect it to work in this case since it's just replacing the M6 yaw sensor with one from an A6,
Eich is offline   Reply With Quote
Old 06-08-2013, 04:41 PM   #7
cbass
Drives: .
Nice work.
The fact that this has to be done while other manufacturers let you disable it is stupid.
cbass is offline   Reply With Quote
Old 06-08-2013, 06:08 PM   #8
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Kewl
Sent from my DROID RAZR using Tapatalk 4 Beta
tramtwo is offline   Reply With Quote
Old 06-08-2013, 10:26 PM   #9
RonnieG
RonnieG's Avatar
Drives: 2013 AGM 1LE/2SS/RS
you the man!
RonnieG is offline   Reply With Quote
Old 06-08-2013, 11:14 PM   #10
MPHS_AGM
MPHS_AGM's Avatar
Drives: 2013 Camaro 2SS/RS/1LE AGM
Thanks for the props! I have been off the boards for a while and glad to see that there was some progress made on disabling HSA. Do you know if the automatic sensor needs to be calibrated? There is a section in the manual about calibrating the yaw sensor and I can't recall if it was only for the HSA function. I will reread the sections and see what I can come up with. Keep us posted on any changes to the traction control system.
Current:
2013 AGM 2SS/RS/1LE-NPP
Past:
2002 Z28 Navy Blue A4 [traded]
1996 Camaro V6 Black [traded]
MPHS_AGM is offline   Reply With Quote
Old 06-08-2013, 11:20 PM   #11
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Instead of an automatic YAW sensor, can someone use one from a 2010-2012 Manual? Or is the part number/sensor the same?
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 06-09-2013, 04:38 AM   #12
t&t moyer
It's all hers.
t&t moyer's Avatar
Drives: 2015 ZL1
Looks like the 10-12 are the same as the OP mentioned automatic version.
http://www.gmpartsclub.com/oem-part/...ensor/13578326
t&t moyer is offline   Reply With Quote
Old 06-09-2013, 06:39 PM   #13
x1sniper3x
x1sniper3x's Avatar
Drives: 2013 CRT 2SS/1LE; 2016 Colorado Z71
Awesome!! I've been working around/living with the HSA for a while now but it's nice to see someone did the homework to find a fix! Although it is sad that this has to be done instead of just disabling it. As long as no one has any glaring issues I'll be doing this myself. Thanks for the write-up!!
x1sniper3x is offline   Reply With Quote
Old 06-10-2013, 12:40 AM   #14
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
The part will be on backorder soon!
