BORLA
Old 06-08-2013, 08:43 AM   #1
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
THOSE OF YOU INSTALLING YOUR OWN CAMS STEP INSIDE
Something everyone should be doing when installing a Cam in an LS engine is a Case Learn Procedure.
This is also called a Crank Learn Procedure.
With your SCT device you have this Option, if not you will have to find someone with a capable Scanner, Tech2, HPtuners or EFI Live to Perform this function.
What this does is Syncronize your Cam, and Crank Signals with the Computer.
This should be done any time you change a Cam or Engine or after reflashing of a your computer.
It is in the Special Functions portion of your SCT Tuner.
The vehicle must be fully warmed up, parking brake on, and follow the on screen Prompts.
I caution everyone that the fuel cut is 4K, be ready to let off the gas when it hits fuel cut, or if for some reason the system is not ready and goes right by it.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 06-08-2013, 09:16 AM   #2
amerimuscle
Drives: 2011 Camaro 1SS
Does your mail-order tune for cams do this already?? or is this in addition to your tunes?
amerimuscle is offline   Reply With Quote
Old 06-08-2013, 09:53 AM   #3
JANNETTYRACING
This is a Special function Feature that is Part of the SCT Device.
You must do this procedure after a Cam install.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 06-08-2013, 10:12 AM   #4
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
".........or after reflashing of a your computer."
That sounds like we should do this even if we don't have a cam?? Does it?
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 06-08-2013, 10:15 AM   #5
JANNETTYRACING
It certainly won't hurt anything, it's like that second coat of wax in your case.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 06-09-2013, 09:29 AM   #6
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Ted.
Ted does the HP tuner have this function?
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 06-09-2013, 10:43 AM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Yes it does sir.
Old 06-09-2013, 11:00 AM   #8
amerimuscle
are there noticeable differences (performance-wise or drivability) to having the cam and crank signals syncronized?
Old 06-09-2013, 11:10 AM   #9
RJT-SS
RJT-SS's Avatar
Ted.
Thanks. I don't understand the "fuel cut" statement in the OP. Would you please explain?
Performance Mods:
Old 06-09-2013, 11:32 AM   #10
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
Ted.
So are there are alot of people out there that have installed a cam themselves and have a JRE- SCT tune but have not yet done this procedure? Is this learning procedure something newly discovered or just something that some people have been overlooking?
If it is like a second coat of wax, or to (fine tune a tune) with basic bolt ons, then is it a good idea for everyone who has tuned their car to do this?
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 06-09-2013, 11:54 AM   #11
RJT-SS
RJT-SS's Avatar
.....exactly.....that is what I am trying to figure out. My car runs great (better) after the JRE tune but what do I really gain by doing this? I get the second coat of wax analogy but I would really like more details. I am sure Ted will fill us in.
I also wonder if there are any more "coats of wax" like this we can apply?
Performance Mods:
Old 06-09-2013, 08:42 PM   #12
ToddB
Drives: 2011 2SS Convertible Supercharged
-uck I hate waxing. But if Ted says to wax. Then wax on it is.
2011 Camaro SS, LS3,Whipple SC, 13 PSI,CAI intake, ARH 2" Headers, Corsa exhaust, ZL1 fuel pump with ADM FPCM LS9 Cam and Meth,ID850, BMR suspension upgrades,Tune by JRE
ToddB is offline   Reply With Quote
Old 06-09-2013, 09:04 PM   #13
NOT URSS
NOT URSS's Avatar
Drives: 2010 2SS/RS Camaro
Send a message via AIM to NOT URSS
I'm sure if it wasn't done it would of thrown a code. Tech2 won't work with 5th gens.. The new GDS will.
632RWHP/556RWTQ
NOT URSS is offline   Reply With Quote
Old 06-09-2013, 09:09 PM   #14
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
This procedure has been around a long time, pre ls1 acutally. It shouldn't be needed on a bolt on car with the stock cam and original ecm. Only if the ECM has been changed, new cam, new crank or new engine. Once its set, its there.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
