Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V8
Old 06-08-2013, 11:24 AM   #1
Drives: 2012 45th
cross brace removal when supercharged
i have a 2012 ls 3 convertiable 6 speed with cold air ,long tube headers and mgw short throw shifter. if i add a tvs 2300 supercharger will i have to remove the tower brace permanetly
re2de2 is offline   Reply With Quote
Old 06-08-2013, 11:50 AM   #2
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Nope. You should have enough clearance. You'll know more when you put it back on though. It's only three bolts on each side.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
Chris82xx is offline   Reply With Quote
Old 06-08-2013, 02:29 PM   #3
Iam Broke
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Nope, mine fit. See below or my garage.
Didn't even have to pull the cross brace for the SLP (new style) install since the SC is bolted onto the mani/he after that is in place.
Iam Broke is offline   Reply With Quote
