BeckyD @ James Martin Chevy
Old 06-08-2013, 01:52 PM   #1
the_fast_one
the_fast_one's Avatar
Drives: 2012 IOM 2SS, 05 SOM Colorado
what cam can I run until i do s/c
I'm planning on getting blow this winter and shooting for 700rwhp. At the moment I am doing supporting mods. I have the basics Cai and muffler delete, but the car has 5k mikes so wanting a little more before voiding warranty. At the end of the month ill have my drivetrain bought and hopefully installed. I'll have pfadt zl spec stage 2 kit, gm 3.91 gears, 1000hp axles, single piece alum ds, and probably a clutch. Hoping by august I can do cam, head work, lt headers and a dyno tune and blow my warranty in one big grinning hp gain. Around January ill be shipping the car off to get blown. Looking at the ecs kit at the moment. Now that you know my plan hopeful I can get a good recommendation for a cam. I have read that mid level cam is good both n/a and s/c. Want something with a lop and some decent hp gains but would really like it to help more with the s/c application.
Thanks. I've searched and read a few threads but couldn't really find to much
the_fast_one is offline   Reply With Quote
Old 06-08-2013, 03:01 PM   #2
Unreal
Drives: 2006 Z06
Stock cam will make 700-800 all day long with a decent Fi kit.
Nick
Corvette Z06 -1200ish rwhp
Old 06-08-2013, 04:48 PM   #3
the_fast_one
I know it can but I want to enjoy the sound a cam makes also.
Old 06-08-2013, 05:07 PM   #4
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Either have a shop custom pec one or get a stage 2 blower cam. I have a custom cam in mine, as they can make more power and drive better than an off the shelf unit, but the stage 2 blower cams are street friendly and will have the sound you want.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 06-08-2013, 05:16 PM   #5
the_fast_one
Thanks I will look into those options.
Old 06-09-2013, 09:25 AM   #6
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '112SS/RS'12CruzECO'11CruzeLTZ,Mini
Either have a shop custom spec one or get a stage 2 blower cam. I have a custom cam in mine, as they can make more power and drive better than an off the shelf unit, but the stage 2 blower cams are street friendly and will have the sound you want.
What he said.
Running a VR Comp Custom Spec here. Numbers put it somewhere between a Stage2 and 3. Still good street manners.
If plan on going FI ,3.91 may be too much gear. May want to hold off on the 3.91s now or drop back down after going FI. Best wishes with your build.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X,Monster Triple,Alky Control Meth Inj Feb12th Install.
SSBUSDRVR is online now   Reply With Quote
Old 06-09-2013, 11:01 AM   #7
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Originally Posted by the_fast_one View Post
Want something with a lope and some decent hp gains but would really like it to help more with the s/c application.
These two are not necessarily mutually beneficial.
The lope you mention is due to the LSA, or Lobe seperation angle. A narrow angle will result in lots of lope, while a wide angle will not.
Typically forced induction applications want a wide LSA. This ensures the exhaust valve closes prior to the intake valve opening, therefore keeping the intake charge, in this case a forced charge, in the cylinder.
The narrow angle LSA helps with a N/A application in that the scavenging effect of the properly designed exhaust system helps pull the air/fuel charge into the cylinder since the intake valve opens prior to the exhaust valve fully closing...
Your biggest gain with the forced induction is going to be with a fairly wide LSA profile cam. The "best" sound is from the narrow angle LSA.
My cam is a 121 LSA, and typical narrow angle cams are in the 110 degree area.
I have very little lope... which adds to a sleeper aspect...
Take a look at the Lingenfelter GT-9 cam. Some very mild lope but great for forced induction applications.
I used to have the GT-9 Cam, but when we exceeded it's RPM range and capability, we went to a custom grind designed by my builder and Graham Behan at Lingenfelter. It allows us to make more power to a higher range of RPM's. I sacrifice quite a bit of torque on the low end and some on the high end but I don't race at low RPM's. And in some cases, mine, losing a little bit of torque down low and through the mid range helps...
Just my thoughts...
When all else fails, call ECS and see what they recommend.
Old 06-09-2013, 12:09 PM   #8
Unreal
Drives: 2006 Z06
Not 100% true. Lope is moslty from overlap, which is largely dictated by LSA but intake and exhaust duration also play a part. Low LSA cams usually have lots of overlap but you could have a 116lsa with more lope than a 110lsa just because of the intake/exhaust duration.
There are tons of good cams and I wouldn't go overboard with FI cam. I run a 228/240 in my 427 and it drives great and still make 1000+hp. Let the blower/turbos do the work.
Nick
Old 06-09-2013, 12:33 PM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Semantics discussion... and yes, duration affects the overlap, which affects the LSA...
It's all somewhat tied together....
Old 06-09-2013, 01:53 PM   #10
se7en
Drives: 87 Pinto on 32's
I have a LPE GT9 Cam for sale that should work great for you.
http://www.camaro5.com/forums/showthread.php?t=281247
se7en is offline   Reply With Quote
Old 06-09-2013, 03:54 PM   #11
the_fast_one
Pm sent
Old 06-09-2013, 06:01 PM   #12
se7en
PM Replied
Old 06-09-2013, 07:18 PM   #13
the_fast_one
Got my cam bought. Thanks se7en
Old 06-09-2013, 07:50 PM   #14
se7en
No problem buddy, it will ship in the am.
