BeckyD@RodgersChevrolet
Old 06-08-2013, 05:29 PM   #1
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
2013 1LE, 12.991 E/T, 100% stock
I just returned form the drag strip and I wasn't going to leave until I saw a 12 second ET
Notes
  • 100% bone stock 2013 1SS/1LE (tires, intake, tune, weight blah blah its all stock)
  • Child seat in back, full gym bag, some quick detailer, 2 California dusters, road side kit and a bunch of towels in the truck (25lbs? total)
  • Temps were 68 when I started at noon and 72 and sunny when I left.
  • 1/2 tank of gas (93 octane)
  • Elevation 827 feet above sea level
  • Drove an hour with no cool down and ran a 13.2 out of the box with rear tires at 35PSI
  • Track was slippery, tires spun
  • Shifted when the tach said 6200
  • Hot lapped twice with 2,13.0s....
  • Let it cool 1/2 hour and dropped the psi to 27/28, ran the same
  • Track was oiled down so I sat 2 hours and dropped PSI to 25.
  • Ran more 13.0s and then the 12.991
  • Called it a day!
What I learned....
  • You MUST shift into 4th
  • 35 to 25 psi made no real difference in 60ft times.
  • Car will run 12s, 100% stock.
Math tells me with a set of drag radials I can run a 12.8 with a 1.9/60 and a 12.6/.7 with a 1.8 60ft....
Matt
PS: If any Cold Air Intake companies want to prove their product works bolt-on without a tune let me know as I am pretty consistent in this thing
Old 06-08-2013, 06:07 PM   #2
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Great job Matt! So the 12.7 put up by MT is doable... maybe with a splash of fuel and no baby seat?
Sent from my DROID RAZR using Tapatalk 4 Beta
tramtwo is offline   Reply With Quote
Old 06-08-2013, 06:15 PM   #3
Dropspeed
Dropspeed's Avatar
Thanks. Yeah its doable. But ideal conditions would need to apply. Prepped track, cool air and some abusive shifts would do it.
I had to drive mine home so I couldn't "go for broke" but I think I rung her out the best I could today.
Old 06-08-2013, 06:24 PM   #4
Craig B
Craig B's Avatar
Drives: 2013 1LE
Congrats!!! Just think if it was a cool 50 degrees out and the DA was - . You may have an .70 or .80 pass in it all stock.
Craig B is offline   Reply With Quote
Old 06-08-2013, 06:49 PM   #5
Dropspeed
Dropspeed's Avatar
Thanks....It would have been a .40 at Englishtown! Seriously you guys have some good air out there!
And on a side note the ZL1 splash guards did their job keeping the rubber off the paint. I see about $20?, $30?, $40? in rubber in my wheel wells.....I just hope it is not all mine
Old 06-08-2013, 06:54 PM   #6
Supercharged SS
Drives: 2010 Camaro
Here's your corrected time:
Old 06-08-2013, 07:03 PM   #7
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Well there we have it... how can the SS equipped with 1LE, which requires a shift into 4th, be a half second faster than a stock SS?
Old 06-08-2013, 07:07 PM   #8
Supercharged SS
Drives: 2010 Camaro
It's not:
Old 06-08-2013, 07:12 PM   #9
Dropspeed
Dropspeed's Avatar
At least I would be in 15th position on that list...(I know, not same trans gearing or rear end gearing....)
Old 06-08-2013, 07:48 PM   #10
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
That's my point... the guys at the top of that list have some serious 1/4 mile seat time. Do they not? I think your workman like runs are awesome Matt. 15th on THAT fast list with a baby seat strapped in. Woot!!
Old 06-08-2013, 07:53 PM   #11
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
You're corrected time would have you fifth. The lighter wheels have to be the difference. Guess we can't make a direct comparison. Interesting non the less.
Old 06-08-2013, 09:27 PM   #12
Dropspeed
Dropspeed's Avatar
I wasn't sure If they made the list using actual or corrected times. I am very happy if it is corrected times.
I should have also noted above that I did not use the launch mode in any of the runs. I held the traction control down for the 7 seconds to turn everything off. I would come off the clutch quickly at about 2800-3000 rpm but feather it to control wheel spin. The car would spin the tires to about 4000 rpm and then hook and go.
Matt
Old 06-08-2013, 09:31 PM   #13
Supercharged SS
Drives: 2010 Camaro
Matt
That is the official stock list. NO corrected times.
Old 06-09-2013, 09:10 AM   #14
Dropspeed
Dropspeed's Avatar
Gotcha. Either way I feel pretty good. Just trying to figure out how The leader got it to hook and run an 8.1 1/8.
