Caryle Racing
Old 06-08-2013, 06:04 PM   #1
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
What did you use, S/c install
Re-installing my vortech ysi supercharger bracket. I know the instructions don't call for anything but did YOU use any locktite or anti seize on the bracket bolts?
K32 Camaro is offline   Reply With Quote
Old 06-08-2013, 07:26 PM   #2
blake-b
blake-b's Avatar
Drives: Black 2010
I did not use locktite except where the instructions said to (crank pulley, blower pulley and anywhere else I forgot to mention). I did use antiseize on the bolts that go into the head.
The rest of them I just tightened down.
It won't hurt to use blue (medium strength) anywhere you see fit.
Old 06-08-2013, 07:50 PM   #3
K32 Camaro
V8 lounge member #5
I was just surprised that it didn't say to on the bracket bolts, specially when you're mixing metals like that.
Old 06-08-2013, 10:12 PM   #4
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
I didn't do the ORIGINAL install on my setup, but recently I had to take the blower off which means I had to take all the bracketry off. There was no lock-tite on those bolts and I didn't use any when reinstalling. I just tightened down and went about a 1/4 turn after that.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 06-08-2013, 11:07 PM   #5
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
I don't like thread lockers. I use them almost never. Proper torque.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
