Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 06-09-2013, 12:23 AM   #1
Thapilot
Drives: 2010 2SS Black Twice
F/S: Hurst Shifter Bushings
*******SOLD********I bought a shifter from another member, he had the original bushings plus the replacement from Hurst. My fellow members & the vendors that were making them did not have any in stock and I wasn't willing to wait for an uncertain amount of time to get them so I had someone make me a set. It wasn't worth his time to only make one set so he made me 10 sets including mine. I have 9 sets of these brass bushings with o-ring channels cut into them. I gave him my shifter, the hurst replacement bushings and had him make them to fit my shifter. I can confirm that these fit my shifter and work fine, I completed the install tonight. I had the channels cut for the O-rings because I didn't want the buzzing/rattling metal sounds. Ok...that's a lot of talking. I've tried to give you pictures of every aspect you might want to see and as much info as possible. I didn't have to make any modifications to these for (MY) installation, early 2010 SS model.
I'll provide the O-rings I used but you can always use your own (the ones from hurst are a tighter fit than the ones I used). With the O-Rings in I did have to tap the bushing into the shifter openings so the fit is very snugg, and because there is an O-Ring where the bevel meets the shaft I used some pliers to seat the bushings in place as they would not fit into the shift arm that goes into the trans unless I did (this took minimum pressure with a set of pliers).
I have almost no noise when accelerating hard in any gear including 2nd & 4th and no more play than stock that I can tell. I did use the noise kit on the shifter handle only (flat stick) for my install.
Hope this answers most the questions you might have. Again, I only have 9 pair, first 9 to PM...
$32 (includes bushing, O-rings)
If you have any questions let me know!
Thapilot is offline   Reply With Quote
Old 06-10-2013, 06:43 AM   #2
Thapilot
Old 06-10-2013, 06:27 PM   #3
Jay5748
Drives: 2013 rs/ss
PM sent
Jay5748 is offline   Reply With Quote
Old 06-10-2013, 09:14 PM   #4
Thapilot
Reply sent.
Originally Posted by Jay5748 View Post
PM sent
Old 06-10-2013, 10:42 PM   #5
RRTX-SS
RRTX-SS's Avatar
Drives: 2010 2SS/RS M6
im assuming these will only fit a hurst shifter right??
2010 Camaro 2SS/RS
416 CI M6-LS3 Kenne Bell 3.6, Livernois Dual Fuel Pump Kit w/KB BAP, Futral Motorsports Blower Cam, SW 2"Headers, Zl1 Dual Mode Exhaust, Street Slayer Billet Twin-Disc Clutch,PFADT lowering springs and sway bars, Iforged Classic Wheels, AI Meth Injection, rx dual checkvalve catchcan, Innovators West 8-Rib pulley setup....690RWHP/701RWTQ @ 10 PSI-CALIBRATED BY KARGER @ SNL PERFORMANCE
1995 Camaro Z28 LT1 M6
383 Fully Forged shortblock
RRTX-SS is offline   Reply With Quote
Old 06-11-2013, 01:32 AM   #6
R3VOLUTION-SS
Drives: 2010 Victory Red SS
PM sent.
R3VOLUTION-SS is offline   Reply With Quote
Old 06-11-2013, 03:39 PM   #7
Thapilot
RRTX, I didn't try them with any other shifter so I'm not sure, but they were made using the hurst as the template.
If you will be in Dallas anytime soon and I have some we can try it if you haven't installed yet.
Old 06-11-2013, 05:46 PM   #8
R3VOLUTION-SS
Payment sent. Thanks Thapilot!
Old 06-11-2013, 07:17 PM   #9
Thapilot
Anytime....going out tomorrow!
Old 06-11-2013, 09:04 PM   #10
RRTX-SS
RRTX-SS's Avatar
just bought a zl1 short throw shifter which i can wait to install ........will let you know next time im in dallas thanks bud
2010 Camaro 2SS/RS
Old 06-17-2013, 10:05 PM   #11
BITCHIN CAMARO
BITCHIN CAMARO's Avatar
Drives: 2010 Camaro RS SS
Installed last night. Bushings work great!
BITCHIN CAMARO is offline   Reply With Quote
Old 06-17-2013, 11:56 PM   #12
The 2010 Sin
weaponsinc.com
The 2010 Sin's Avatar
Drives: 2014 Lifted 1500, 2013 2SS CRT
they look nice too
The 2010 Sin is offline   Reply With Quote
Old 06-18-2013, 02:32 AM   #13
pyro449
pyro449's Avatar
Drives: 2010 SIM Camaro 2 SS/RS
pm sent
2010 2SS/RS LS3/M6 SIM. More money than I want to think of in mods.....
pyro449 is offline   Reply With Quote
Old 06-18-2013, 07:27 PM   #14
Thapilot
Thanks for the Rob, I'm glad they worked for you!!!
