JUICEDMOTORSPORTS
Old 06-09-2013, 04:57 AM   #1
AbidaL
Drives: 2010 Camaro V6 2LT/RS
LED Decoder Hyper Flash Fix!
Does anyone know how to make this fit for the tail lights?
http://store.ijdmtoy.com/3157-LED-Hy...s-p/aa1069.htm
AbidaL is offline   Reply With Quote
Old 06-09-2013, 07:34 AM   #2
sjmautoprod
sjmautoprod's Avatar
Drives: '10 1LT
The keying shown in the photos is not the same as on the tails.
sjmautoprod is offline   Reply With Quote
Old 06-09-2013, 11:18 AM   #3
iKeablr
iKeablr's Avatar
Drives: Chevrolet Camaro 2011 RS 1LT
Those won't work on the tail lights. They will still hyper flash and you lose the parking lights at night for the brake lights. You need a 3 wire harness and I also have that and doesn't work for the brake lights, still hyper flashes.
Camaro 2011 VR 1LT RS - Prometheus Prime
|Leather Interior|Leather Door & Dash Trim|12" Subwoofer|Dash ABL|Plasma DRL|
iKeablr is offline   Reply With Quote
Old 06-09-2013, 08:50 PM   #4
AbidaL
So that means the only way is to use load resistors?
if yes, then how and what is the best way to mount them for the tail lights?
because mine get very hot and make the tail light cover also hot, I'm afraid it might melt them. they also hyper flash whenever it rains :S
Old 06-09-2013, 11:23 PM   #5
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
If you can wait a few days, I'm going to do a thread on how I just did mine. Really pressed for time right now. Sorry. So far, no issues with load resistors.
N.O. Plate(dedicated fuel tank, progressive, fuel hose upgrade, remote opener, heater, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 06-10-2013, 07:38 AM   #6
sjmautoprod
Drives: '10 1LT
They do get very hot and you need to position them so that they are not in the path of water draining down the channels on each side.
Old 06-23-2013, 02:18 AM   #7
AbidaL
did you do a thread on how you did yours yet?
